Thread: Sparkplug and Misfire problems.
Results 1 to 16 of 16
  1. #1 Sparkplug and Misfire problems.
    GT Level Member deadsnake's Avatar
    Round lake, IL
    Okay I have a 2004 SC Monte carlo ss, I have a 3" catless zzp dp, CAi and a tuned pcm from Reptile, I was recommended to buy replacement autolite 606 copper spark plugs, I went today to change them, started driving down the road for a test and the car started sputtering, came back to the garage took the plugs out and 3 of them cracked , okay so then i went to the auto shop and bought a set of NGK iridium spark plugs instead, replaced those and same thing still sputtering and misfiring, then i went and bought a set of duralast wires replaced those and same outcome but this time i had some smoke coming out and i dont know wtf is going on, at autozone i had the chick there read me the codes hat got thrown out. they are
    p1664 skip shift 1-4 upshift lamp control circuit fault. probable cause open or short circuit condition in the driver circuit, failed or missing bulb.
    p0140 ho2s12 circuit condition heated oxygen sensor bank sensor 2, probable cause engine misfire condition-repair, oxygen sensor defective, fuel system running very rich or lean check other codes first, fuel pressure very high or low fuel pump or pressure regulator
    p0654 engine speed output control circuit fault, probable cause failed tachometer or instrument cluster error, open or short circuit condition on output speed circuit, driver circuit ecm defective.....
    SO please I need some help!!
  2. #2 Re: Sparkplug and Misfire problems.
    Jul 2008
    sumter,south carolina
    how hard did u tighten the plugs?
    02 GTP with mods 05 GP for DD
  3. #3 Re: Sparkplug and Misfire problems.
    Donating Users gtp239's Avatar
    ft myers fl
    ya check the plugs i had some autolite 104s crack brand new and it was doing the same thing
    1998 gtp fwi, sd headers, overkill,3.4, poly mounts,p&psc
  4. #4 Re: Sparkplug and Misfire problems.
    Round lake, IL
    they are in there very tight
  5. #5 Re: Sparkplug and Misfire problems.
    Jul 2008
    thats ur problem.... all they need is a good snug 1/4 turn after hand tightening.. ur messing the plugs up over tightening them.
  6. #6 Re: Sparkplug and Misfire problems.
    Round lake, IL
    il try to see what happens...
  7. #7 Re: Sparkplug and Misfire problems.
    Round lake, IL
    lets say i do that and the same thing happens what then?
  8. #8 Re: Sparkplug and Misfire problems.
    Jul 2008
    did u knock a vac line loose when doing the plugs?
  9. #9 Re: Sparkplug and Misfire problems.
    Round lake, IL
    a vac line? Im not sure what that is, i replaced all the spark plug wires though
  10. #10 Re: Sparkplug and Misfire problems.
    Jul 2008
    LOL vaccuum lines that go into Intake mani, throttle body, map sensor, etc etc
  11. #11 Re: Sparkplug and Misfire problems.
    Round lake, IL
    Not that I know of...... I can take a pic lol
  12. #12 Re: Sparkplug and Misfire problems.
    Jul 2008
    doubt a pic will help... go trace all the lil plastic thin lines that go around ur motor and make sure none are cracked or completely disconnected... cant miss them.
  13. #13 Re: Sparkplug and Misfire problems.
    Round lake, IL
    Il; go check that out, but lest say everything is in place.
  14. #14 Re: Sparkplug and Misfire problems.
    Round lake, IL
    I didnt see any loose wires or anything....it only sputters when i boost.
  15. #15 Re: Sparkplug and Misfire problems.
    Round lake, IL
    can it be that the plugs are offset wrong?
  16. #16 Re: Sparkplug and Misfire problems.
    Donating Users alkygto's Avatar
    Nov 2009
    wentzville
    Be sure to check the boots on the vacuum lines, they tend to split.
    1997 Pontiac Grand Prix GTP
    1969 Pontiac GTO
  1. Do I need new sparkplug wires?
    By Smalltownmodder in forum Off Topic Discussion
    Last Post: 04-23-2010, 04:50 PM
  2. 2 different misfire problems fixed
    By GtpKo in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-07-2010, 01:01 PM
  3. EGR valve problems and cyclinder misfire
    By rmortime in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-03-2010, 11:59 PM
  4. sparkplug melted
    By blowfishRus6 in forum General Tech Discussion
    Last Post: 04-12-2009, 05:22 PM
  5. Stock Sparkplug's
    By stlmo_gtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-18-2008, 01:58 AM
