Thread: 20 PSI of boost!!!!????
Results 1 to 20 of 30
Threaded View
  1. #1 20 PSI of boost!!!!????
    SE Level Member kirkkarem1212's Avatar
    waterford, MI
    yes, 20 psi of boost at 5700 rpm shift. i took it back down to a 5200 rpm shift and im hitting 15psi. still to much id say. im running a 3.1 and a intense stage 1 cam. gen 3, headers, no cat, no u bend, borla cat back (2.5), and stock injectors. but im not running lean, so i dont think fuel is the problem. im thinking it may be timed wrong. but it holds a pretty steady vac and doesnt run bad. i didnt install the cam. so i wasnt there to double check it at the time. feels a little slow for all my mods. im thinking it might be off a tooth or something. also it hit 1-2 KR on 100% 110 race fuel. anything it could be other than the timing?
    i need help quick, woodward is less than a week away!
    3.4 pulley, Borla Cat-Back, Headers, 3" Downpipe, Cat Del, Volt Booster, Trasher Air Box, K&N Filter, Intense Stage 1 Cam, 105# springs, Powder Coated TB, S/C, And Fuel Rails.
  1. Why is my boost gauge only reading vacuum and no boost?
    By gtp02 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-21-2010, 02:26 PM
  2. dic boost gauge only shows half boost
    By SilvaMan61 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-10-2010, 07:40 PM
  3. Low boost
    By jtemple54 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-29-2009, 03:21 PM
  4. How much boost?
    By Bigbm80 in forum General Tech Discussion
    Last Post: 07-09-2009, 04:01 PM
  5. only 4 lbs boost???
    By orange97gtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-29-2009, 04:50 PM
