Thread: 20 PSI of boost!!!!????
Results 1 to 20 of 30
  1. #1 20 PSI of boost!!!!????
    SE Level Member kirkkarem1212's Avatar
    waterford, MI
    yes, 20 psi of boost at 5700 rpm shift. i took it back down to a 5200 rpm shift and im hitting 15psi. still to much id say. im running a 3.1 and a intense stage 1 cam. gen 3, headers, no cat, no u bend, borla cat back (2.5), and stock injectors. but im not running lean, so i dont think fuel is the problem. im thinking it may be timed wrong. but it holds a pretty steady vac and doesnt run bad. i didnt install the cam. so i wasnt there to double check it at the time. feels a little slow for all my mods. im thinking it might be off a tooth or something. also it hit 1-2 KR on 100% 110 race fuel. anything it could be other than the timing?
    i need help quick, woodward is less than a week away!
    3.4 pulley, Borla Cat-Back, Headers, 3" Downpipe, Cat Del, Volt Booster, Trasher Air Box, K&N Filter, Intense Stage 1 Cam, 105# springs, Powder Coated TB, S/C, And Fuel Rails.
  2. #2 Re: 20 PSI of boost!!!!????
    I live here. TLSheff's Avatar
    That is a crap ton of boost out of a m90
    are you still running stock pcm or has the car been tuned? that might affect the timings, fuel ratio, things like that but i wouldn't think it'd give that much boost tho
  3. #3 Re: 20 PSI of boost!!!!????
    waterford, MI
    it has been tuned. lots of times lol but that reading of 20 psi at 6500 rpm is from my boost gauge. not from a scanner.
  4. #4 Re: 20 PSI of boost!!!!????
  5. #5 Re: 20 PSI of boost!!!!????
    waterford, MI
    clogged cat?
    Has no cat. No u bend. 3" dp. 2.5 all the way back. Headers.
  6. #6 Re: 20 PSI of boost!!!!????
    GT Level Member sic6's Avatar
    san marcos, tx
    you might have alot of carbon build up on either the exhaust ports or intake manifold ports. This would restrict the flow and cause excessive boost. Or could be your gauge is not working properly.Try and run a scan to see what numbers your getting off boost.
  7. #7 Re: 20 PSI of boost!!!!????
    waterford, MI
    Quote Originally Posted by sic6 View Post
    Brand new motor. 700 miles on it. Try again.
  8. #8 Re: 20 PSI of boost!!!!????
    Hey i said 35...I wasn't far off was I?
  9. #9 Re: 20 PSI of boost!!!!????
    waterford, MI
    Help me out blue, Wth is going on with my car? You seem to know your stuff.
  10. #10 Re: 20 PSI of boost!!!!????
    Donating Users Tengis's Avatar
    Houston
    6500rpm shift points? Please tell me you arent tuning this car.
    Your pulley is too small by a size or two. If you are getting knock on 110 then you are doing something wrong.
    Silver R32 Skyline GTS-T
    Satin Purple 97 GTP
    Blue 01 IS4 + M112 hybrid GTP
    Satin Black 98 Turbo GTP
    ZZP recommended installer - Kratos Concepts
  11. #11 Re: 20 PSI of boost!!!!????
    Your shifting kinda high for a 3800 for one. Any SES lights? Sure you don't have a faulty BBV or something? X2 what was said above...maybe you need some serious tuning work.
  12. #12 Re: 20 PSI of boost!!!!????
    May 2008
    staten island,NY
    maybe the boost guage is faulty
  13. #13 Re: 20 PSI of boost!!!!????
    Or tapped in the wrong place.
  14. #14 Re: 20 PSI of boost!!!!????
    waterford, MI
    I've got a guy that tunes everyones cars in my area. He knows his stuff.
  15. #15 Re: 20 PSI of boost!!!!????
    not with a 6500 shift point he doesnt. there is no power up there to be had.
  16. #16 Re: 20 PSI of boost!!!!????
    waterford, MI
    Sorry guys, my bad. 5700. Sorry I'm a lil retarded
  17. #17 Re: 20 PSI of boost!!!!????
    May 2008
    staten island,NY
    on that note id say check to see where the boost gauge line is tapped into
  18. #18 Re: 20 PSI of boost!!!!????
    Charles City, IA
    No where should have 20psi of boost. Try another gauge.
    SMGPFC Two Nipple General
  19. #19 Re: 20 PSI of boost!!!!????
    waterford, MI
    if timing was off could this happen? the cam timing
  20. #20 Re: 20 PSI of boost!!!!????
    May 2008
    staten island,NY
    you're jumping the gun, why not start simple.? check how the boost gauge is hooked up. it takes all of opening the hood.
  1. Why is my boost gauge only reading vacuum and no boost?
    By gtp02 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-21-2010, 02:26 PM
  2. dic boost gauge only shows half boost
    By SilvaMan61 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-10-2010, 07:40 PM
  3. Low boost
    By jtemple54 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-29-2009, 03:21 PM
  4. How much boost?
    By Bigbm80 in forum General Tech Discussion
    Last Post: 07-09-2009, 04:01 PM
  5. only 4 lbs boost???
    By orange97gtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-29-2009, 04:50 PM
