you guys added 30% for the e85 was that after you did the correct injector conversion for switching the injectors to 65lbs injectors? As what MAf are you running is it a stock MAf or after market? and did you import that correct table for that MAf? i run e85 and never had that happen i believe when i first switched my LTFT's were already at -1.562 @ idle and around -3.24 at cruise, which is just about what they were when i was running regular gas
