yea man you can send me the bin and i will be more then happy to look at it for you, btw your running the 78mm TB which calls for a aftermarket MAF doesn't it? i have never seen the 78mm in person but from what i read from zzp it says the MAF hole is closed so you have to use an external aftermarket one is this correct? if so i will have to know what kind of MAf you have (LQ4,LQ6, or maybe you opened the hole back up and have a stock MAF in there?) these are very important things
