Thread: Header hitting sway bar and power steering lines
Results 1 to 20 of 35
  1. #1 Re: Header hitting sway bar and power steering lines
    How was that UN chill? I'm just tellin ya since you said they "seemed" fine but yet you said one side was lower than the other which indicated that the fluid had spilled out from the factory mount and is now trash. Replace them with the solid rubber ones too, not the hydraulic fluid filled ones.
  2. #2 Re: Header hitting sway bar and power steering lines
    Donating Users bbptech's Avatar
    Box Elder, South Dakota
    well i dont have a damn clue bout the lower engine mount. but i guess something new learned. if i get the solid rubber mount, it isnt gonna wear out quick?
    ZZP 10.4mm's, ZZP S2 IC, 3.4, 3.0, Ported Gen V, ZZP Headers, ZZP CNC Heads, ZZP 78mm TB, ZZP Aluminum Valve Covers, Meziere Electric WP, ZZP Fuel Pump, ZZP Fuel Logs, 65 Mototrons, 3.29's, 2500 Stall. Tuned by GLANZERGTX and Kyle. E85 Converted, 21* Timing
  1. power steering?
    By X97prixX in forum General Tech Discussion
    Last Post: 01-14-2010, 04:02 PM
  2. Power Steering
    By Pontiac Warrior in forum Brakes/Suspension/Chassis
    Last Post: 07-07-2009, 11:51 PM
  3. Front Upgraded sway bar hitting.....
    By I4NI in forum Brakes/Suspension/Chassis
    Last Post: 03-16-2009, 10:20 AM
  4. Power Steering
    By SuperCharged6 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-31-2008, 05:01 PM
  5. power steering
    By Toasty in forum General Tech Discussion
    Last Post: 02-23-2008, 01:24 PM
