Thread: New 02 GTP Anniversary Issues
Results 1 to 19 of 19
  1. #1 New 02 GTP Anniversary Issues
    Aug 2011
    Taylor
    Hey guys, I just bought a mint condition 02 GTP Anniversary, with a new trans/engine. Also told S/c was new as well but I don't believe it, for 5500$. Anyway when I rev up the engine the boost gauge is only showing half boost, same with then I floor it. I have messed with the Boost Bypass Actuator and when I have somebody hold it down, and i rev up the car, the boost guage shows full, Could it be my Actuator causing the reason I do not get full boost? The car does not bog at all or anything when I get on it, I just think it does not get full boost, I feel like it should be faster, Also I have a check engine light that is reason to low of air flow/MAF needs to be cleaned, If I replace my MAF sensor could that help? Thanks guys I really appreciate it.
  2. #2 Re: New 02 GTP Anniversary Issues
    GT Level Member kuntzie's Avatar
    Feb 2010
    Kitchener, Ontario, Canada
    The gauge doesnt read full boost like that, and the car is stock it's proably not that quick
    You need a new maf most likely
    02 Grand Prix GT Intercooled turbo 5-speed 718whp 618wtq @ 21psi 7575 billet, spool valve, custom manifolds, 4" downpipe, 16way adjustable coilovers, 18x9.5 with 275's all around, gxp interior, gxp brakes
    tilton triple disc, custom aluminum flywheel, tilton slave and master, an awful lot more
  3. #3 Re: New 02 GTP Anniversary Issues
    Aug 2011
    Taylor
    So my boost gauge should only fill up halfway? On other videos it shows it filling up full, and I have had other people tell me it should, and I know Its not that quick lol. But then why would it show full boost when I hold the actuator lever down? I dont think It touches the bottom all the way. And a new sensor or mass air flow itself
  4. #4 Re: New 02 GTP Anniversary Issues
    Quote Originally Posted by kuntzie View Post
    yes on the MAF...and no on the gauge. If your going by the DIC gauge...even stock it will go all the way up...boosting 7 LEGO's YAY! But if it isn't...most likely the issue is pertained to that MAF sensor OR there is a vacuum leak.
    Quote Originally Posted by 02GTPanniversary View Post
    You can always go to your local junkyard and yank a new BBV off of a supercharged Series II/III car...they are all the same from '97+. You could also have a vacuum leak...check all of the rubber "T" fittings around the BBV, to the FPR, to the LIM (under the supercharger snout) and back to the MAP sensor...they all tend to dry rot...and I've seen some that don't leak until there is boost applied thoughout the system, but don't appear torn or rotted...
  5. #5 Re: New 02 GTP Anniversary Issues
    Aug 2011
    Taylor
    Yay okay, yeah I had a fit with the Ts, I had one come off under the map sensor abd couldn't find it lol, I got It though the one under the altenator has a crack in it, but I taped It all up, but gauge is still showing the same, i hope its the mass air flow sensor thats only a 120$ fix.
  6. #6 Re: New 02 GTP Anniversary Issues
    Aug 2011
    Taylor
    And where can I buy the rubber ts would like to have new ones.
  7. #7 Re: New 02 GTP Anniversary Issues
    You can get the vacuum fittings from your local dealership...
  8. #8 Re: New 02 GTP Anniversary Issues
    Aug 2011
    fredericksburg virginia
    my car had the same problem, was a bad boost solenoid. cost me 20 bucks from the dealership i work at. gauge would only go up halfway and lack of power. mine had set a p1646 in the pcm which did not turn on the MIL, here is the circuit description from the online service manual, Output Driver Modules (ODMs) are used by the PCM to turn on many of the current-driven devices that are needed to control various engine and Transaxle functions. Each ODM is capable of controlling up to 7 separate outputs by applying ground to the device which the PCM is commanding ON. Unlike the Quad Driver Modules (QDMs) used in prior model years, ODMs have the capability of diagnosing each output circuit individually. DTC P1646 set indicates an improper voltage level has been detected on the output circuit which controls the supercharger Boost Control Solenoid.
  9. #9 Re: New 02 GTP Anniversary Issues
    Aug 2011
    Taylor
    Holy moly sounds confusing. Can I just get a solenoid and replace that? Lol.
  10. #10 Re: New 02 GTP Anniversary Issues
    Aug 2011
    Taylor
    Hey when I disconnected the vacuum line to the solenoid I got full boost and was quicker, would it be bad to run with it disconnected till I get a new solenoid ?
  11. #11 Re: New 02 GTP Anniversary Issues
    Aug 2011
    it wouldnt be bad per say, but fuel economy would suffer. you could do it temporarily but i would recommend replacing the solenoid as soon as possible.
  12. #12 Re: New 02 GTP Anniversary Issues
    Aug 2011
    Taylor
    By leaving it unplugged, would it suck stuff in?
  13. #13 Re: New 02 GTP Anniversary Issues
    Aug 2011
    If you're worried about that could could just cap it off.
  14. #14 Re: New 02 GTP Anniversary Issues
    Aug 2011
    Taylor
    I thought about it, but its a vacuum line so It sucks in. If I cap It off won't the boost not get full potential
  15. #15 Re: New 02 GTP Anniversary Issues
    Texas
    You mean the boost bypass valve? What solenoid are you referring to?
    If you do mean the BBV yes some will just cap it off and bypass it completely. It won't hurt anything.
    85 Corvette
    01 TA
    03 Z06
  16. #16 Re: New 02 GTP Anniversary Issues
    Aug 2011
    Taylor
    Yes the solenoid below the Bybass Valve, with the sensor plugged into it, I just disconnected the vacuum line, that has the T's on it. And left that unplugged runs great, still great gas mileage, bout 22mpgs. And hauls ass.
  17. #17 Re: New 02 GTP Anniversary Issues
    um thats a bad idea to leave the vacuum lines unplugged, your cars running SUPER lean.
    22mpg is pretty bad really, seeing how I can get 30ish and 24ish mixed.
    You should fix the issue for real this time.
  18. #18 Re: New 02 GTP Anniversary Issues
    Aug 2011
    Taylor
    Well I just got the car about 2 weeks ago, so I haven't driven it long enough to get up that high in mpg. I have been kinda getting on it seeing as I have a 45 min ride to work, I also only run 89 octane. Alls I'm doing is unplugging the vacuum line connecting to the left side of the solenoid, it still runs acts fine, and gets just about full boost, like one block away from full.. It'll get to full takes a mintue, you think if I just replace the solenoid it'll fix the issue?
  19. #19 Re: New 02 GTP Anniversary Issues
    Aug 2011
    Taylor
    I'm only leaving the one unplugged from the solenoid, nothing else
  1. 40th anniversary
    By sportred04 in forum Off Topic Discussion
    Last Post: 03-03-2011, 08:56 PM
  2. Anniversary present!
    By JCG's-GTP in forum Off Topic Discussion
    Last Post: 03-24-2008, 04:19 PM
