Thread: Throttle Bodies ?
Results 1 to 12 of 12
  1. #1 Throttle Bodies ?
    GTX Level Member stlmo_gtp's Avatar
    St. Louis
    now that i have finished my exhaust i was going to buy a new throttle body and just wanted to get some input from you guys on which on i should go with
  2. #2 Re: Throttle Bodies ?
    mods?
  3. #3 Re: Throttle Bodies ?
    not worth it unless youre to the 3.2 pulley area. you might gain a horsepower or two.
  4. #4 Re: Throttle Bodies ?
    St. Louis
    cool thanks that's all i really needed to know i am not at a 3.2 pulley stage yet, so i will just wait on in until i get to that stage
  5. #5 Re: Throttle Bodies ?
    Never hurts to have a stock ported TB. Talk to Reptile. I had mine done during the cam install but a buddy just got his done along with his ported S/C case. Better throttle response and MPG's too. Not just all about numbers Butt dyno likes em
  6. #6 Re: Throttle Bodies ?
    St. Louis
    yea i was looking into that actually, can i use the same stock MAF after i have ported it?
  7. #7 Re: Throttle Bodies ?
    Barksdale AFB, LA
    Quote Originally Posted by stlmo_gtp View Post
    You can, but you'll need MAF tuning since the MAF tables will be really off. It'll throw your trims pretty positive.
    I have a TB ported by Reptile and I love it. Great throttle response. Of course, I installed it when I did my top swap so that may have added to the effect.
    2009 Subaru Impreza WRX STI
  8. #8 Re: Throttle Bodies ?
    ^^ The man does good work
  9. #9 Re: Throttle Bodies ?
    St. Louis
    i will have to shoot him a pm and get a price, can i buy a different MAF instead of messing with the tables on my stock MAF?
  10. #10 Re: Throttle Bodies ?
    Barksdale AFB, LA
    No. It's not the MAF itself that's the problem. It's that you're changing the diameter of the TB around it. That will change its readings for a given airflow.
  11. #11 Re: Throttle Bodies ?
    Quote Originally Posted by Sabrewings View Post
    Yup...more air...different readings...have to tune for it
  12. #12 Re: Throttle Bodies ?
    St. Louis
    ok cool looks like the next thing i will be saving up to buy is a tuner
  1. LS1 or N* Throttle Body
    By 2000GTP2708 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-25-2012, 08:19 AM
  2. N* throttle body
    By 99prixgt in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-21-2009, 01:41 PM
  3. part throttle kr
    By Sabrewings in forum PCM Tuning
    Last Post: 06-09-2008, 09:30 PM
