Thread: Installed plog (and DP) and now issues! (w/vid)
Results 1 to 20 of 25
  1. #1 Installed plog (and DP) and now issues! (w/vid)
    GT Level Member SliceTheRice's Avatar
    South Jordan, UT
    My friend and I put on a ZZP plog the other day and for the most part everything seemed to go well. I drove the car around and it seemed fine. Then when I went to go give it some good throttle I got this weird backfiring sputtering going on. I've been suspecting that I've had a clogged cat for some time so I before I freaked out about it I went and had the 3" catted DP installed to see if the cat was the problem. After the DP install, it's doing the exact same thing. It idles just fine and if you drive it conservatively, you would never guess something was wrong.
    In this vid you can see that if you take the RPMs to 4.5 is starts doing that sputtering thing. It seems like it just might be the rev limiter, but if I'm at a light and then pin it, it will do the same thing at lower RPMs (just not consistently like in the vid. It will sputter for a second and then move on). Similarly, if I'm on the freeway cruising along at 2 RPMs and then pin it the car will shift down, sputter a bit and then take off with no problem. I spoke to another friend and he suspects the coils are the cause, but I'm at a loss as to how putting in a plog could blow my coils!
    Please take a look (listen) to the vid and let me know if you have any ideas at all! (If you have good computer speakers with decent bass range, you'll hear it better). Like I say, this could very well just be a video of the rev limiter working like it should but I don't know if I can effectively video whats going on while I'm driving. This is just to give you a sense of what I'm hearing when I put the engine under a heavier load.
    Thank you!!
    2000 Pontiac Grand Prix GTP
    (3.4 MPS, DHP 1.0 tune, ZZP Plog & 3" DP, 2.5" cat-back exhaust, resonator delete, AL104 plugs, 180* T-stat, Falken Ziex 245/45/18 tires)
  2. #2 Re: Installed plog (and DP) and now issues! (w/vid)
    Jan 2009
    Tallahassee, FL
    I'd look into ignition issues, I assume no SEL?
    Maybe even a clogged fuel filter or maybe air filter?
    05 Saab 9-2X Linear (Saabaru)
    77 Morris Garage B
  3. #3 Re: Installed plog (and DP) and now issues! (w/vid)
    South Jordan, UT
    No, no codes and the air and fuel filter were just changed recently.
  4. #4 Re: Installed plog (and DP) and now issues! (w/vid)
    Jan 2009
    Tallahassee, FL
    Then I'd start looking at your ignition.
    77 Morris Garage B
  5. #5 Re: Installed plog (and DP) and now issues! (w/vid)
    Jul 2008
    sumter,south carolina
    maybe burnt a plug wire on plog? id inspect wires.
    02 GTP with mods 05 GP for DD
  6. #6 Re: Installed plog (and DP) and now issues! (w/vid)
    Jan 2009
    Utica Missouri
    Im gonna say burnt plug wire on plog, Or firing order off?
  7. #7 Re: Installed plog (and DP) and now issues! (w/vid)
    Donating Users chrisb's Avatar
    Bucyrus, OH
    is it loosing power at all?
    99 Grand Prix old build- CAI, Custom exhaust, HV3, Stage 2 TB, custom tune, ported heads intense s1x cam, headers.
    Nothing great Just a small T66 Turbo with a Hv3 On a stock tranny untill i finish the other one.
  8. #8 Re: Installed plog (and DP) and now issues! (w/vid)
    Apr 2009
    stockton ca
    thats the rev limiter try and do that in neutral should raise the rpms for the rev limit and see it is does it
  9. #9 Re: Installed plog (and DP) and now issues! (w/vid)
    South Jordan, UT
    THANK YOU for all the posts/suggestions guys - I really appreciate it!
    Quote Originally Posted by Green97GTP View Post
    I talked to another friend tonight about this and he suggested the same thing. He said the same thing happened to him when he replaced the LIM gasket. I will for sure check them out and will see what I can find. When we did the plog we did have to pull the front wires off to get them out of the way.
    Quote Originally Posted by chrisb View Post
    Eh, when it's doing the brief sputtering thing, yes. But once it stops, it's like the car goes back to complete normal and takes off like usual.
    Quote Originally Posted by TorqueAutoMotiv View Post
    Yeah, that's what I thought. I'll try your neutral suggestion and see what happens.
    Thank you again to all for the input - very much appreciated. If anyone has any more thoughts or ideas in the meantime, feel free to shout them out. Thanks again!
  10. #10 Re: Installed plog (and DP) and now issues! (w/vid)
    Jul 2008
    firing order for front from left to right is 1,3,5 seemed to be running to smooth for firing order screwed up... id put money its a burnt plug wire.
  11. #11 Re: Installed plog (and DP) and now issues! (w/vid)
    South Jordan, UT
    With a bad wire you think it could still run smooth at times other than heavy load?
  12. #12 Re: Installed plog (and DP) and now issues! (w/vid)
    Apr 2009
    stockton ca
    Quote Originally Posted by SliceTheRice View Post
    yea under heavy load theres more current so if it is burnt at idle its not arching but under heavy accel it would arch hard and draw current away from plug
  13. #13 Re: Installed plog (and DP) and now issues! (w/vid)
    Jul 2008
    yes... my headers burnt #3 wire and it ran normal at idle... give it gas and it bogged down.
  14. #14 Re: Installed plog (and DP) and now issues! (w/vid)
    South Jordan, UT
    Sweet guys, thanks! I'm going to take a look at the wires tomorrow and see if I can't get to the bottom of this. I'll update later. Thanks again!
  15. #15 Re: Installed plog (and DP) and now issues! (w/vid)
    GT Level Member Black18Ice's Avatar
    Iowa
    I thought it was just the rev limiter too, but if not then you try the maf sensor. Just unplug it and see if it makes it better.
  16. #16 Re: Installed plog (and DP) and now issues! (w/vid)
    That sounded like it was hitting the rev limiter... My car did that when i tried to get past 3 lbs of boost, turned out the ICM was bad. Replaced that and now its all good.
    Have you tried scanning for codes?
  17. #17 Re: Installed plog (and DP) and now issues! (w/vid)
    South Jordan, UT
    Ok, so yesterday I went out and messed around with the front set of wires before taking it for a long drive. I drove it for quite some time and it STOPPED DOING THAT STUPID SPUTTERING THING! It drove great for about a good hour and then on the way home it started doing it again. So later I did a closer inspection of those wires, looked for burns, external damage or wear, and I couldn't find any. I put them back on and tried to make sure they weren't touching anything (as much as possible anyway) and then drove it around some more last night. No hiccups. Then on the way to work (abt 45 minute drive) it didn't do anything stupid either.
    So I'm going to keep my eye on it, but fooling around with the wires definitely made a difference.
  18. #18 Re: Installed plog (and DP) and now issues! (w/vid)
    How about getting new wires? You can get the Autozone lifetime Duralast wires for like $30.
  19. #19 Re: Installed plog (and DP) and now issues! (w/vid)
    South Jordan, UT
    I probably should, huh. Yeah, I probably will. Just to be safe.
  20. #20 Re: Installed plog (and DP) and now issues! (w/vid)
    And they are lifetime warranty too...so anytime you fubar one...you can bring them in and exchange them for a good set.
  1. Plog and D/P installed!
    By JoelW98GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-09-2009, 09:03 PM
  2. PLOG
    By mpiacent in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-22-2009, 12:44 PM
  3. Installed PLOG, now studders under boost. Please help!
    By nickbuol in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-18-2009, 10:07 AM
