Thread: timing chain replacement question
Results 1 to 14 of 14
  1. #1 timing chain replacement question
    utah
    So my car is at 215k and never changed the timing chain...would it be a good idea or is it ok to just keep it on? Car is still running amazing!
  2. #2 Re: timing chain replacement question
    it would be good for you to change it. the tensioner or probably toast by now which means the chain isnt too far behind.
  3. #3 Re: timing chain replacement question
    GTX Level Member cerick08GP's Avatar
    Well, I would definitely say it is a good idea to have it changed. However, since the engine is still running well I would leave it for now. The nice thing about metal timing chains is they usually don’t self destruct and take your engine out with them. The next time the car needs some shop time you might want to tack on the chain replacement then.
    Ten years of continuous driving excitement and counting!
    2008GP
    ||HV3 insert||PowerSlot rotors w/Hawks||LED interior||MSD 8.5mm
    2002GP||sold
  4. #4 Re: timing chain replacement question
    Outer Space
    I ran stock can until around 140k, and changed it when I pulled the engine/tranny out. I agree with the posters above.
    02 GTP 13.6 @ 100mph - SOLD
  5. #5 Re: timing chain replacement question
    Quote Originally Posted by cerick08GP View Post
    the chain does explode when the tensioner cracks, breaks, and then leaves the sprung metal tab to grind into the chain.
  6. #6 Re: timing chain replacement question
    Donating Users Ibwrong's Avatar
    Oklahoma City
    and hell while your in there might as well throw a cam in there! I would also suggest replacing it with that many miles!
    2000 GTP - Project
    2000 Mustang GT
    2006 Charger
  7. #7 Re: timing chain replacement question
    ^^Not really...the valvetrain might not be up to it unless he just did a VS...just put a new timing chain and dampner in there...also, I'd put a '04+ Oil Volume Kit in there...its just like ZZP's advertised oil psi booster but in all actuality is just an '04+ spring/gasket. That way your motor will have a bit more oil pressure to help its longevity.
  8. #8 Re: timing chain replacement question
    utah
    so when replacing would you also do the sprockets or just the chain/dampener. I figure do that and the water pump too since ill have it off. I just wanna keep the thing running as long as possible, especially since i just replaced the trannny.
  9. #9 Re: timing chain replacement question
  10. #10 Re: timing chain replacement question
    Water pump, sure. I can see that...but the gear itself is fine. Just clean it and reinstall.
  11. #11 Re: timing chain replacement question
    New Jersey
    A few things i'm confused about.
    I thought you always change sprockets with a chain, in fact I thought they came as a set?
    Also why would you change a roller cam. Don't the rollers in the lifters prevent like 98% of the wear you experience with flat tappets?
  12. #12 Re: timing chain replacement question
    who said you wanted to replace the cam...?
    replace whatever comes with the set, ive never done it since i went with a double roller chain and never looked back.
  13. #13 Re: timing chain replacement question
    Apr 2009
    stockton ca
    when i pulled my engine apart with 185k the timing set looked decent slight wear on the tensioner and my cam didnt have any real wear on it niether did the crank all the machine shop did was polish them
    just fyi
  14. #14 Re: timing chain replacement question
    New Jersey
    Bio : IBwrong recommended it perhaps the nickname means something?
    BTW, isn't the stock chain double roller? Just looked it up. guess not
  1. Timing Chain cover
    By timboku in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-14-2010, 10:02 PM
  2. timing Chain
    By Zach3800 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-21-2010, 11:12 PM
  3. timing chain
    By pure in forum General Tech Discussion
    Last Post: 08-16-2009, 02:00 PM
  4. Which timing chain to get.
    By PWNED in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-20-2008, 09:01 AM
  5. Which timing chain?
    By whitcomb in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-01-2008, 04:49 PM
