Thread: 3.4 Setup Issues
Results 21 to 40 of 41
  1. #21
    Largo, Florida, United States
    BUY A BOOST GAUGE AND STOP GUESSING AT YOUR CAR MAKING BOOST OR NOT!!
    jesus christ...got all that money into your interior and you cant buy a $40 boost gauge and hook it up. that will tell you 100% if you have a vacuum leak or if you're not making 'full' boost.
    I'm picking up one from my friend in tampa in a week.
    Vac leak, you knocked something loose putting on the pulley.
    minichopper put the pulley & new ZZP Coupler in while the engine was apart. then picked it up a week later ported
    Last edited by Bio248; 05-17-2010 at 07:28 PM. Reason: stop double posting. take the time to do it right. you're being lazy.
  2. #22 Re: 3.4 Setup Issues
    Charles City, IA
    Buy a $4 can of carb cleaner and find your vac leak.
    SMGPFC Two Nipple General
  3. #23 Re: 3.4 Setup Issues
    Jul 2008
    sumter,south carolina
    i almost would put money its the T boot under snout.
    02 GTP with mods 05 GP for DD
  4. #24 Re: 3.4 Setup Issues
    ^^THIS.
    Any rubber "T" fittings around the LIM and the the one running from the TB to the EVAP.
  5. #25 Re: 3.4 Setup Issues
    Banned - Busted For Scamming
    Feb 2009
    They have all been replaced he said.
  6. #26 Re: 3.4 Setup Issues
    Jul 2008
    could have knocked it loose on pulley install
  7. #27 Re: 3.4 Setup Issues
    ill go buy another set of New "T Boots" and new Vac lines Ill find this ****.
  8. #28 Re: 3.4 Setup Issues
    Donating Users Ibwrong's Avatar
    Oklahoma City
    Did you find rubber T's I have been looking all over the place for some or are you using the hard t's?
    2000 GTP - Project
    2000 Mustang GT
    2006 Charger
  9. #29 Re: 3.4 Setup Issues
    Quote Originally Posted by Ibwrong View Post
    Dealership. That's the ticket there.
  10. #30 Re: 3.4 Setup Issues
    I was using the hard T's from autozone.
    didnt know they had rubber ones
  11. #31 Re: 3.4 Setup Issues
    Oklahoma City
    Thanks Nick #2 Always forget about the stealership when it comes to little parts like that.
    2000 GTP - Project
    2000 Mustang GT
    2006 Charger
  12. #32 Re: 3.4 Setup Issues
    Delaware, OH
    What's the bbv solenoid delete and what's the purpose if you don't mind me asking.
    And to the OP if you took the throttle body off or whoever installed the headers took it off, I'd remove it again and make sure no old gaskets jammed between mating surfaces.
    No More GTP for me.
    2014 Chevy Cruze ECO Manual. 40+MPG
  13. #33 Re: 3.4 Setup Issues
    GTX Level Member Juanmiguel's Avatar
    Mexico
    i bought rubber T's at autozone too.
  14. #34 Re: 3.4 Setup Issues
    I buy them from the dealer because the one form the BBV all the way back to the MAP is only $18. Saves a lot of headache too because it comes with all new plastic lines and rubber fittings...I then lubed them just to prevent future dry rotting...or at least dry rotting as fast as most of them do. It's just as the saying goes work smarter not harder...
  15. #35 Re: 3.4 Setup Issues
    Outer Space
    My bet is TB gasket.
    02 GTP 13.6 @ 100mph - SOLD
  16. #36 Re: 3.4 Setup Issues
    Quote Originally Posted by Lawngoose View Post
    why do you say that? i have a brand new gasket
    and To Nick (Blue) i went to price check that Vac line and it was 30$ with the Rubber T's from the dealership. Aren't the ones GM sells (plastic Vac lines) really ****ty? i know my original ones broke when i was installing my LIM gasket a few months back.
  17. #37 Re: 3.4 Setup Issues
    Charles City, IA
    buy a $4 can of carb cleaner and find where the leak is!
  18. #38 Re: 3.4 Setup Issues
    Apr 2009
    stockton ca
    check for the leaks before actually throwing parts at the car
  19. #39 Re: 3.4 Setup Issues
    how can i use that to find the leak?
  20. #40 Re: 3.4 Setup Issues
    Charles City, IA
    Spray it around the engine and when the leak is found the idle will go up. Please read stuff... It has been stated time and time again.
  1. New tool box setup
    By TorqueAutoMotiv in forum Off Topic Discussion
    Last Post: 02-09-2010, 07:32 PM
  2. Setup to go for?
    By Dthreap in forum Turbo
    Last Post: 01-26-2010, 08:50 PM
  3. my old setup
    By whitcomb in forum Audio, Security & Visual Electronics
    Last Post: 12-21-2009, 06:49 PM
  4. New setup
    By b00stinGTX in forum Brakes/Suspension/Chassis
    Last Post: 02-25-2009, 11:00 PM
  5. this setup
    By gotboost3 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-06-2008, 08:47 PM
