the O2 sensor is the most over replaced item in the emmissions related items and its the most over looked as standard maintnance
Its easy to test it though put a micrometer Or scaner on the car and see if the volts jump up and down in relation to gas
the tach issue sounds like the crk sensor as stated
and if the rear o2 sensor is reading high to low voltage probably means your cat is in need of replacement
