Thread: 4 Trouble codes/TCS and RPM issue.
Results 1 to 14 of 14
Threaded View
  1. #1 4 Trouble codes/TCS and RPM issue.
    Florida
    1999 GTP 3800 V6
    Took the car to an O'rielly Auto Parts and read the codes with their device and had the following pop up:
    Catalyst System Efficiency Below Threshold (Bank 1)
    Research shows the code P0420
    Evaporative Emission Control System Pressure Sensor High Input
    Research shows the code is P0450
    Exhaust Gas Recirculation Error (EGR Number 2)
    Research shows the code is (possibly) P1404
    Symptoms:
    Sometimes the vehicle turns over but does not start, usually turning the key off and on a few times the car will start up roughly then idle out regular.
    Resonator has a busted out hole on the top, patched it for the time being with a muffler sheet metal kit.
    Seems to be some kind of liquid, like water, near where the down pipe bolts to the manifolds that smokes. Only noticed this once.
    While driving the car sometimes chokes and dies. Happens at random times, but often just cruising at 50-60, not revving up or down.
    While driving the car seems to "skip" once and then the RPM gauge drops to zero, TCS off light comes on and stays on. Car continues to run fine just no RPM read and the TCS light stays on even if you press the button. Restarting the vehicle seems to correct.
    Actions so far:
    Patched resonator.
    Used Seafoam, adding half a can to a half a tank of gas, half a can to the intake via the brake booster vacuum hose.
    Based on the above information (and/or information provided if questions are asked below), please suggest what might be causing the above trouble codes and RPM/TCS issue. Thanks.
  1. trouble codes
    By grand2000prixgtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-09-2009, 05:12 PM
  2. trouble codes
    Last Post: 08-19-2009, 02:32 PM
  3. Trouble codes
    By probuilder1 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-17-2009, 09:51 AM
  4. trouble codes
    By BADAZGTP in forum Forum Bugs/Suggestions
    Last Post: 07-26-2008, 10:59 AM
  5. trouble codes.
    By hotshot in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-11-2008, 06:58 AM
