Well figured it out, it'll start because hee fuel pump is on at startup, then the fuel pump turns off after running for about 5 seconds. I have found that the fuel pump shut down relay is turning off the pump for some reason. If I bypass that relay it will stay running and runs fine. The OBD2 system give no codes. What would make this relay trigger a shutdown?
Thanks,
Paul
