Thread: Fun Surging
Results 1 to 20 of 34
  1. #1 Fun Surging***FINALY FIXED***
    Hoffman/Schaumburg, IL
    ***Update 6/12/2008:
    Ok, so after fighting this issue for months I tried a few things, I unplugged the maf for a week, the surging remained, but the car didn't stall. So after talking to James and him stating that the VE tables in my PCM probably aren't that good(it is a off-the-shelf Bin). I figgured I would bite the bullet and purchase a new Maf, long story short, a the MAF was bad, which was further complicated by my off VE table
    So props to toasty who was the first with the right answer
    Well this all started about 3 days ago, not a rough idle, but a hunting idle. Sometimes it drops to like 300 rpm then shoots back up to 1500 rom then levels out into the hunting idle. Then yesterday it started stalling out on me.
    Finnaly last night it threw a code, so I went to autozone to get it read:
    P0102- which could be like five different things, but pretty much low vacume in intake manifold.
    What I have done,
    Used carb cleaner to check for leaks around the UIM and Throttle body
    Cleaned MAP and MAF
    Checked all hoses and vac lines
    Checked EGR(tried to clean but damn near impossible to get that thing clean)
    Cleaned PCV and checked o-ring
    Now it sounds a little like vacuum around the throttle body, could this be normal, or could it be the infamous cracked UIM.
    The dealer is gonna take it on friday cause the warranty, but I have a deductible on my warranty and wish to avoid it, any other suggestions on what I should check
  2. #2 Re: Fun Surging
    GTP Level Member Toasty's Avatar
    SW Chicago Suburbs
    i think autozone doesnt know how to read... or you gave us the wrong code --
    P0102
    MAF Sensor Circuit
    Low Frequency
    This DTC detects a
    continuous short to low or
    open in either the signal
    circuit or the MAF sensor.
  3. #3 Re: Fun Surging
    nice, the person at autozone was very disspleased that they had to help me, but the print out does say p0102
    but when I unplug the maf the car doesn't run, it starts and revs to like 2k then dies, so there is some other issue as well
    could a bad maf cause the surging and stalling?
  4. #4 Re: Fun Surging
    SW Chicago Suburbs
    could be bad maf, or could be issue with wiring to the maf
  5. #5 Re: Fun Surging
    Banned
    New Port Richey Florida
    No No No check and clean the Idle air conrtol valve. The hunting idle is a sign that the pcm is not seeinig the value for idle it likes and its hunting for it thus you get surging. I'd suggest check and clean the iac.
  6. #6 Re: Fun Surging
    SW Chicago Suburbs
    Quote Originally Posted by 19SE92 View Post
    and just ignore the MAF trouble code????
  7. #7 Re: Fun Surging
    I cleaned it spotless when I cleaned the maf, the tech at carmax is having a hell of a time finding it as well, I had to go there show him the problem, and explain to him all my mods so he knew what he was working around, but nice dude
  8. #8 Re: Fun Surging
    Ok, got my car back from carmax, had to pay a hundred bux for them to run every test under the sun, but they couldn't find my problem, they eliminated:
    Vacuum Leak
    Fuel Issue
    and some others, I don't wanna just throw parts at it, but I think a new or new/used MAF sensor is going on this week then we will go from there, any other Ideas?
  9. #9 Re: Fun Surging
    GTX Level Member Andrew_99GTP's Avatar
    New Salem, ND
    Kind of sounds similar to my problem. I have swapped out all the throttle body sensors with known good ones and nothing changed. Are you running a maf screen, if not put it back in for starters. If I unplug my IAC my car idles perfectly but with it plugged in it hunts sometimes worse than others.
    Red 2dr 99 GTP"Old" Z7 t66, A/A IC'd, Custom Heads, 65# Inj, ST2 Cam, Meziere Elec Pump, JP Double Roller(with machined crank gear), Plogs, PLX W/B, Powrtuner SOLD
    "New" 2007 Duramax ccsb with a few mods
  10. #10 Re: Fun Surging
    SE Level Member GTP2K1's Avatar
    Tampa, FL
    You set a Maf code so start there, unplug it an look at the connectors in the plug if they look clean make sure the wires aren't damaged, if they appear fine then try replacing it, if the new one doesn't solve the problem then take it back off an return it. No harm done but then you can start thinking about other possibilities.
    Cheap, Fast, Reliable... you can only pick two
    http://www.cnfcgp.com/
  11. #11 Re: Fun Surging
    To help everyone help me here is a list of what I've done:
    Checked function(unpluged and ran car, problems still remained)
    MAF
    MAP
    TPS
    EGR
    EVAP
    IAT
    Ive, blocked off the following, no change:
    EGR
    EVAP
    I've replaced with good and problem still exsists:
    Coils
    ICM
    Plugs
    Wires
    Pcv
    Notes:
    Bouning vacuum, enging runs fine anytime mre than about 10% throttle is applied
  12. #12 Re: Fun Surging
    See first post for update!!!
  13. #13 Re: Fun Surging
    TDCRacing
    Guest
    glad u got it worked out
  14. #14 Re: Fun Surging
    SW Chicago Suburbs
    Yay!
  15. #15 Re: Fun Surging
    I gave you rep for being correct
