Thread: Running Lean
Results 1 to 6 of 6
  1. #1 Re: Running Lean
    Charles City, IA
    Quote Originally Posted by Planeboy18 View Post
    Going full throttle while running lean will cause the car to go into PE mode. I would stay out of the throttle for a while will you figure out what's wrong, which is probably a vacuum leak as mentioned before or an O2 sensor.
    PE mode is for when you go WOT. Running lean before that will actually just add more fuel in PE mode.
    SMGPFC Two Nipple General
  2. #2 Re: Running Lean
    SE Level Member duneking905's Avatar
    Feb 2010
    san diego
    there was a vacumm line loose next to the alternator. i put it back in its place and the car runs better
  1. Running Stoich to Lean
    By jersey jok3r in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-12-2009, 08:47 PM
  2. Engine running lean
    By crd783 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-09-2009, 01:26 AM
  3. STILL running lean..why!?
    By BwolfGT in forum General Tech Discussion
    Last Post: 10-22-2009, 12:26 AM
  4. running lean or rich + white smoke on idle
    By Talsition in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-17-2009, 08:51 PM
  5. Is running lean safe?
    By BwolfGT in forum Off Topic Discussion
    Last Post: 10-13-2009, 07:46 PM
