Thread: supercharger
Results 1 to 20 of 21
  1. #1 supercharger
    Brownsville, Tx
    i have a 99 gtp and i replaced my coupler because my supercharger stopped whining, but still with the new coupler the supercharger doesn't whine. does anyone know why this might be happening?
  2. #2 Re: supercharger
    GTX Level Member 98GTPCALGARY's Avatar
    Feb 2009
    Red Deer AB
    when you had it apart did you try turning everything? to check for slack, and or bad bearings? or have you changed anything else, intake/exhaust?
    98' GTP, 18's, BMR Adjustable Forward & Rear Lateral Arms, BMR Tubular Trailing Arms, Intense PCM, CAI, drilled rotors, 5% Tint all around
  3. #3 Re: supercharger
    GT Level Member skidoojames151's Avatar
    seattle
    maybe the boost bypass valve is stuck not allowing boost, possible belt slippage?
  4. #4 Re: supercharger
    GT Level Member rmcardle3's Avatar
    Houston, TX
    Hey Torres. Yea, Boost “By-Pass” valve is good to check first (expensive $211.00/dealer), but what about the vacuum lines that control the Boost “Solenoid” valve (which controls the Boost “By-Pass” valve). It's the little one (Boost “Solenoid” valve) next to the large one (Boost “By-Pass” valve) with the vacuum line (directly) connected to it. That vacuum line can cause all kinds of trouble, too. Good luck Torres.
  5. #5 Re: supercharger
    Feb 2009
    Red Deer AB
    does the DIC show bars "boost" on the gauge?
  6. #6 Re: supercharger
    'stopped whining' isnt a good enough description. are you making boost? how much boost? do you have a vacuum leak? did you forget a belt?
    need more.
  7. #7 Re: supercharger
    I say the rubber "T" is rotted...20 to 1
  8. #8 Re: supercharger
    Oct 2008
    Northern Illinois
    This
  9. #9 Re: supercharger
    May 2008
    McHenry IL
    agreed
  10. #10 Re: supercharger
    Houston, TX
    Yes
  11. #11 Re: supercharger
    Brownsville, Tx
    how do i check if the boost bypass valve is working???
  12. #12 Re: supercharger
    Feb 2009
    Red Deer AB
    again, do you have no boost? or is it just not noisy anymore? does the boost gauge do anything?
  13. #13 Re: supercharger
    Brownsville, Tx
    it shows boost but not like it used to fill up before.
  14. #14 Re: supercharger
    Brownsville, Tx
    or also how do i know if it is belt slippage?
  15. #15 Re: supercharger
    Feb 2009
    Red Deer AB
    run the car, get somebody else to hit the gas a few times while you watch the belts, look for any pullies not tunning smooth, how is the tensioner arm and pullie?
  16. #16 Re: supercharger
    Aug 2008
    Long Island, New York
    check the bbv
  17. #17 Re: supercharger
    RUBBER T FITTINGS!!
    I know it
  18. #18 Re: supercharger
    Houston, TX
    Quote Originally Posted by rtorres422 View Post
    I agree with bluegtp91. I would say look for the presence of something that would MAKE IT fail. That would be the "rubber T fitting".
    * Open the hood, looking into the engine compartment.
    The vacuum line that starts under the SC nose cone, around the front of the SC, right there is a Rubber T Fitting.
    The “Rubber T Fitting” goes on to directly connect to the "boost (vacuum) solenoid" (next to the larger boost bypass valve). That is why it is important, it can cause everything to go static, until vacuum control is restored. Look at the "Rubber T Fitting".
  19. #19 Re: supercharger
    SE Level Member GTPcoupe's Avatar
    Feb 2010
    Canada
    If you end up needing a BBV, ZZP sells new ones a lot cheaper than the dealership!
    '99 GTP coupe - Growing mod list/summer car
    '98 GTP Sedan - Winter ride, 315,000+kms and going strong!
  20. #20 Re: supercharger
    Houston, TX
    Quote Originally Posted by GTPcoupe View Post
    Really, how much?
  1. How To Supercharger 02 se?
    By jeremybrown1987 in forum How To Write-Ups/Tech Tips
    Last Post: 12-05-2009, 07:07 PM
  2. Supercharger
    By drewz313 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-25-2009, 06:24 PM
  3. Supercharger oil?
    By stewartj1998 in forum General Tech Discussion
    Last Post: 03-03-2009, 09:54 PM
  4. supercharger
    By ldyzluvdis06 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-10-2009, 08:53 PM
