Thread: 280-340 HP build
Page 1 of 5 123 ... LastLast
Results 1 to 20 of 93
  1. #1 280-340 HP build
    Apr 2008
    Any one know of a build that would give me between 280-340 horsepower? I don't want to much because it's going to be street driven daily driver; but i do want enough to spank some GT's with out spending a small fortune. Any help would be appreciated.
    -thanks.
  2. #2 Re: 280-340 HP build
    Barksdale AFB, LA
    Since you're posting in the supercharged area, I assume you already have a GTP. What's stopping you from beating GTs now? That's a 40-60HP difference depending on what series motor you have.
    2009 Subaru Impreza WRX STI
  3. #3 Re: 280-340 HP build
    Oklahoma
    Im wondering if he didnt mean Mustang GT's.
  4. #4 Re: 280-340 HP build
    Barksdale AFB, LA
    That would make more sense...
  5. #5 Re: 280-340 HP build
    GT Level Member Meemperor's Avatar
    Toronto, ON, Canada
    Turbo. Done.
    Lumpy Gen 3
  6. #6 Re: 280-340 HP build
    In Memoriam Rocket468's Avatar
    Yukon, Oklahoma, United States
    Don't take much to hit 280 Intake, Ubend, pulley and reflash. Call all be done for less than 500 and will put you in the Low 13 high 12's
    My EX wifes other car is a broom.
  7. #7 Re: 280-340 HP build
    whoa!
    intake, ubend delete, pcm, and A PULLEY?! youre crazy man. that thing will knock like a beast and will most likely be slower than it was stock.
    supporting mods are completely necessary for any pulley drop, whether it be a 3.6 or a 2.8. honestly, dont tell people they can get away with something that crazy.
  8. #8 Re: 280-340 HP build
    GT Level Member Preotic's Avatar
    Missoula, MT
    280 is cam territory,300 is cam/full size intercool stuff and 340 is more like cam/full size ic/heads/ genv. We are of course talking fwhp not crank.
    L26,Xp, zzp trans,3.29's,2700 conv, slp headers/catback, diy ported heads/LIM, 3 angle valve job,.052 MLS hg, outlet ported Gen V, 3.6, N*, LQ4, 4" FWI, agx's, ssc's, f-bodys, gmpp sway's +stb's
  9. #9 Re: 280-340 HP build
    GTX Level Member kingd44's Avatar
    Feb 2008
    newyork
    alot of people say diff things....the write up on this site says if u do the ubend, dp,pcm,180 stat,then u will be able to drop to a 3.4 pulley wich would then give u a high 13 in the 1/4.........is the write up wrong ??????????
  10. #10 Re: 280-340 HP build
    GT Level Member bayareagtp's Avatar
    Milpitas , Ca.
    i have a lot of those mods w/pcm and i am thinking maybe high-mid 14's as of now maybe low 14's with a 3.5 pulley
    1998 GTP , 3" down pipe w/cat , u-bend delete , full 3" exhaust w/ magnaflows , no resonator , powerslot front rotors , Overkill PCM , Overkill FWI , 180* t-stat , 1* colder plugs , alt. re-wire , alt. stage 1 booster . 215 whp and 238 torque .
  11. #11 Re: 280-340 HP build
    Milpitas , Ca.
    i also beat a stage 1 roush on the freeway unless he didnt know how to drive ? i also barely got beat by a late 90's vette (LS1) unless he didnt know how to drive either (lost by : h is rear bumper was at my front)
  12. #12 Re: 280-340 HP build
    i would guess with my mods and a (badly needed) good tune i could run around the 13.4-13.7 range.
    with the ssic and 3.2 im shooting for 13.1 ish.
  13. #13 Re: 280-340 HP build
    Jan 1970
    Maquoketa, Iowa
    Dropping pulley's is a touchy subject, drop the pulley after you get something to scan knock with. Some people are fine with doing very few mods and then a 3.4". It depends on your car, fuel used, climate and factory freaks. You also don't want to check once for knock and then think you will be fine. Depending on the weather that knock might come back or get worse. You really need either headers or Front P-log/pem + Downpipe to go to a 3.4" after you get a pcm, intake and whatever else you feel will help.
    To get to 280/300 shouldn't take too much depends on how you want to get there really.
    Starters:
    1. Intake- highly recommended wizair or make your own
    2. PCM- buy a HP tuner if you are tuner savvy or go with a custom pcm/tune from overkill/zzp/trannyman
    3. Exhaust- Headers recommended or you can try to get by with a Front powerlog + Downpipe, although I think near 300hp headers is a must.
    3. A full size intercooler or XP cam, xp cam will lope at idle and may hurt gas mpg.
    4. OR a short stack intercooler and 1.9 roller rockers.
    5. OR buy a $2800 turbo kit from zzp and call it good! (sell your m90)
    6. Save up for a tranny rebuild if you beat it!
  14. #14 Re: 280-340 HP build
    Feb 2008
    newyork
    im going to put a wizziard cai, 3' dp ,ubend delete,slp headers,shortstack intercooler,3.4 pulley,180 t stat,and then get a pcm......so i should hit high 13's and be over 300 hp i would think.... no ?????
  15. #15 Re: 280-340 HP build
    Missoula, MT
    ^not gonna get close to 300 with those mods. Most cars with 300 have a cam and intercooler.
  16. #16 Re: 280-340 HP build
    Milpitas , Ca.
    i thought we come stock with close to 240hp ? making an extra 60hp shouldnt be that hard . you figure 5hp u-bend delete , 10hp 3" downpipe , 5-10hp PLOG . right there is 20-25 hp . plus you add a pcm , colder t-stat , colder plugs , air intake of some kind you can figure at least 30-40hp gains then do a smaller pulley (if KR allows) you can see close to 300hp . right ?????? seems right to me anyways .
  17. #17 Re: 280-340 HP build
    Feb 2008
    newyork
    i would think i would der be close if not over thats over $2000 worth of mods i would hope that would get me 60 hp and if not then y spend 2 grand
  18. #18 Re: 280-340 HP build
    GT Level Member rodman's Avatar
    Apr 2008
    whats dp? and plog?
  19. #19 Re: 280-340 HP build
    Quote Originally Posted by bayareagtp View Post
    wow kid, you need to read up on your mods. half that stuff wont add even 1/4 of the advertised horsepower.
    to hit 300 hp with these cars you will more than likely be cammed with a fullsize intercooler as preotic said. that said, these cars are the ones most likely to be running in the 12s with a good tune. people run 12s with rockers on a nice free flowing setup, but it just doesnt have the overall powerband a cam would.
    for a quick car to have fun driving id do:
    header/plog and downpipe (preferences/money), 1.9 modded rockers, a 3.4 pulley, and all the other supporting mods (intake, t-stat, etc.). adding a ported blower and throttle body on top of this only helps to reduce kr. i wouldnt see anyone being able to daily drive a 3.2 pulley on this as it would require low timing and the car will run overall worse.
    for a fast car that youre going to drive on the street:
    list above, but headers for sure and some sort of intercooler. short stack youd be able to run around a 3.2, fullsize youll be able to run anywhere from a 3.2 down to a 2.8 depending upon tune.
    for a balls out fast car:
    instead of rockers you need a cam. upon this would come into the area of heads as well, expensive as fawk.
    so really..make up your mind on what you want your car to do and how you want to drive it before you ask what you can put on your car. also, with all these parts, installing them may be a problem if youre not mechanically inclined. in this case, dont mod your car any more than bolt ons and dont ever drop a pulley.
  20. #20 Re: 280-340 HP build
    Barksdale AFB, LA
    Also, remember that we should really only be talking about wheel HP (WHP) and not crank HP. GM advertises 240HP, but that's at the crank. That will be around 192WHP (~20% drive train loss). To make 300WHP you'd need 375 crank HP.
  1. well I am starting a new audio build. This time it is sq.
    By s1795so2 in forum Audio, Security & Visual Electronics
    Last Post: 05-01-2008, 06:08 PM
  2. My official Triple Edge Performance/trannyman95 transmission build review:
    By shaferz in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-17-2008, 09:18 AM
  3. Build your own city ...
    By dunnster76 in forum Off Topic Discussion
    Last Post: 01-20-2008, 01:32 AM
