Thread: 280-340 HP build
Page 1 of 4 123 ... LastLast
Results 1 to 20 of 93
  1. #1 280-340 HP build
    Apr 2008
    Any one know of a build that would give me between 280-340 horsepower? I don't want to much because it's going to be street driven daily driver; but i do want enough to spank some GT's with out spending a small fortune. Any help would be appreciated.
    -thanks.
  2. #2 Re: 280-340 HP build
    Barksdale AFB, LA
    Since you're posting in the supercharged area, I assume you already have a GTP. What's stopping you from beating GTs now? That's a 40-60HP difference depending on what series motor you have.
    2009 Subaru Impreza WRX STI
  3. #3 Re: 280-340 HP build
    Oklahoma
    Im wondering if he didnt mean Mustang GT's.
  4. #4 Re: 280-340 HP build
    Barksdale AFB, LA
    That would make more sense...
  5. #5 Re: 280-340 HP build
    GT Level Member Meemperor's Avatar
    Toronto, ON, Canada
    Turbo. Done.
    Lumpy Gen 3
  6. #6 Re: 280-340 HP build
    In Memoriam Rocket468's Avatar
    Yukon, Oklahoma, United States
    Don't take much to hit 280 Intake, Ubend, pulley and reflash. Call all be done for less than 500 and will put you in the Low 13 high 12's
    My EX wifes other car is a broom.
  7. #7 Re: 280-340 HP build
    whoa!
    intake, ubend delete, pcm, and A PULLEY?! youre crazy man. that thing will knock like a beast and will most likely be slower than it was stock.
    supporting mods are completely necessary for any pulley drop, whether it be a 3.6 or a 2.8. honestly, dont tell people they can get away with something that crazy.
  8. #8 Re: 280-340 HP build
    GT Level Member Preotic's Avatar
    Missoula, MT
    280 is cam territory,300 is cam/full size intercool stuff and 340 is more like cam/full size ic/heads/ genv. We are of course talking fwhp not crank.
    L26,Xp, zzp trans,3.29's,2700 conv, slp headers/catback, diy ported heads/LIM, 3 angle valve job,.052 MLS hg, outlet ported Gen V, 3.6, N*, LQ4, 4" FWI, agx's, ssc's, f-bodys, gmpp sway's +stb's
  9. #9 Re: 280-340 HP build
    GTX Level Member kingd44's Avatar
    Feb 2008
    newyork
    alot of people say diff things....the write up on this site says if u do the ubend, dp,pcm,180 stat,then u will be able to drop to a 3.4 pulley wich would then give u a high 13 in the 1/4.........is the write up wrong ??????????
  10. #10 Re: 280-340 HP build
    GT Level Member bayareagtp's Avatar
    Milpitas , Ca.
    i have a lot of those mods w/pcm and i am thinking maybe high-mid 14's as of now maybe low 14's with a 3.5 pulley
    1998 GTP , 3" down pipe w/cat , u-bend delete , full 3" exhaust w/ magnaflows , no resonator , powerslot front rotors , Overkill PCM , Overkill FWI , 180* t-stat , 1* colder plugs , alt. re-wire , alt. stage 1 booster . 215 whp and 238 torque .
  11. #11 Re: 280-340 HP build
    Milpitas , Ca.
    i also beat a stage 1 roush on the freeway unless he didnt know how to drive ? i also barely got beat by a late 90's vette (LS1) unless he didnt know how to drive either (lost by : h is rear bumper was at my front)
  12. #12 Re: 280-340 HP build
    i would guess with my mods and a (badly needed) good tune i could run around the 13.4-13.7 range.
    with the ssic and 3.2 im shooting for 13.1 ish.
  13. #13 Re: 280-340 HP build
    GT Level Member rodman's Avatar
    Apr 2008
    whats dp? and plog?
  14. #14 Re: 280-340 HP build
    Barksdale AFB, LA
    Quote Originally Posted by rodman View Post
    whats dp? and plog?
    The Plog (PowerLog) replaces the front manifold.
    The DP (down pipe) is what joins the rear manifold to the catback system. It's named the down pipe because it travels down from the engine under the car.
  15. #15 Re: 280-340 HP build
    I would say my build is in that range of hp moreso on the 300 hp side. I put the money forth on having a very solid bottom end and stuff you cant easily do later. Trust me, you dont want to make a mistake and damage the engine by trying to get a lot of "easy horsepower" like dropping pulley sizes.
  16. #16 Re: 280-340 HP build
  17. #17 Re: 280-340 HP build
    Feb 2008
    newyork
    so somebody has to change that write up then cause its gunna mislead people if u guys r right .....right??? lol
  18. #18 Re: 280-340 HP build
    SE Level Member GTP2K1's Avatar
    Tampa, FL
    Gonna need a full bolt on car, an then take a look at this link an pic your poison for the major mods. Cam, IC, Heads combo.
    CGP-HP - Cam Chart
    Top 5 HP at the wheels cars per Cam. Many with G5 Blowers, IC's An some with heads on top of all that (only major mods listed). An these are the 5 highest recorded cars. So for the most part expect it to take more then whats listed to get those numbers.
    An don't forget about anomalies like Vogel an JohnC (just examples) who tinker with everything shaving ounces off of places sometimes, inventing new one off mods ect.
    Cheap, Fast, Reliable... you can only pick two
    http://www.cnfcgp.com/
  19. #19 Re: 280-340 HP build
    GT Level Member RooK's Avatar
    Apr 2008
    Southern KY
    I'm guessing I'm only around 280whp. I'm running 3.25 pulley, pacesetters, xp cam, ported blower, and so on.
  20. #20 Re: 280-340 HP build
    TDCRacing
    Guest
    Just to help ya'll with a 1/4 mile time estimation i pulled off a 14.4 with the mods in my sig...no engine tune just tranny and a 2.1 60'
  1. well I am starting a new audio build. This time it is sq.
    By s1795so2 in forum Audio, Security & Visual Electronics
    Last Post: 05-01-2008, 06:08 PM
  2. My official Triple Edge Performance/trannyman95 transmission build review:
    By shaferz in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-17-2008, 09:18 AM
  3. Build your own city ...
    By dunnster76 in forum Off Topic Discussion
    Last Post: 01-20-2008, 01:32 AM
