Thread: Rear O2 Emulator?
Results 1 to 9 of 9
  1. #1 Rear O2 Emulator?
    Nov 2009
    United States
    I got ssac headers and will install them soon but i was going to run with out a converter and still needed to pass emmissions so i saw Emulator Rear O2 now will this allow me to pass emmissions? and also where does it plug into? any help would be awesome
  2. #2 Re: Rear O2 Emulator?
    Norristown, PA
    it plugs into your rear o2 sensor, i dont think it will pass emissions.
    it will just get rid of the low eff. cat code.
  3. #3 Re: Rear O2 Emulator?
    just take into consideration that o2 emulators die just like o2 sensors do. if you want to cheat the system space the o2 sensor out so it isnt in the exhaust stream as much.
  4. #4 Re: Rear O2 Emulator?
    Donating Users ls6velless454's Avatar
    Nov 2009
    Portage, IN
    Listen to bio, and save money. I don't know the exact thread pitch on the o2 bung, but they make spark plug no fouler at your locat auto parts store. You just need to get that and install it, not an emulator. Once this is done you will not throw a check engine because your front o2 is sending a certain amount of resistance back to the pcm. When you raise the back o2 it reads less exhaust gases which tricks the computer in believing there is actually a cat there so the o2 has less resistance back to the pcm. Your only problem with emissions is the fact that they use those little mirrors under your car to check if you have a cat installed.
    There is no replacement for displacement........unless you have a supercharger or turbo
    2000 Bright Red GTP Coupe GXP axle back, GMPP sway bar, NGK TR6, 180 stat. (Uninstalled Aeroforce Interceptor, DHP PCM, FWI, Gen V on the way) and still no pulley in sight.
  5. #5 Re: Rear O2 Emulator?
    GTX Level Member imdaman3's Avatar
    Feb 2010
    ohio
    i have the o2 emulator and i passed emisions and it just plugs into were the rear o2 harness is
  6. #6 Re: Rear O2 Emulator?
    Canada
    i did the same thing with the emulator and passed. They would not test my car with the engine light on, the emulator worked to keep the engine light off. My only worry after that was to pass the actual testing and i did with a slp high flo cat.
  7. #7 Re: Rear O2 Emulator?
    Dec 2011
    madison wi
    im considering getting the 02 emulator but concerned its going to affect my gas mileage. Has anyone had that problem??
  8. #8 Re: Rear O2 Emulator?
    if you have a 2001 or up you cant use an o2 emulator. just a heads up.
  9. #9 Re: Rear O2 Emulator?
    And if you could use one..it wouldn't hurt fuel mileage
  1. Any one do this? DIY o2 emulator?
    By abuckley1290 in forum General Tech Discussion
    Last Post: 01-15-2010, 06:54 PM
  2. Rear STB only...
    By a3gtp in forum Brakes/Suspension/Chassis
    Last Post: 03-08-2009, 06:17 PM
  3. O2 Emulator/ Simulator Emissions question
    By Quicklynx in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-24-2009, 11:12 PM
  4. Rear O2
    By probuilder1 in forum General Tech Discussion
    Last Post: 07-27-2008, 10:12 PM
