Thread: 98 GTP smoking problems
Results 1 to 6 of 6
  1. #1 98 GTP smoking problems
    Nov 2011
    Laredo, TX
    So I've been having problems with my 98 GTP and I've changed intake gasket and valve seals but it keeps on smoking and 1 of my spark plugs has oil on it so I took off the supercharger and the intake and there was oil in the intake and I have no clue where its coming from and I need some help anyone have any ideas pls let me know thanks??
  2. #2 Re: 98 GTP smoking problems
    GTP Level Member BlackGT97's Avatar
    Jul 2011
    Michigan
    are you sure the gaskets and seals are installed correctly? its probably one of the two, seems how it just started happening after you changet the gaskets and valve seals.
    1997 Grand prix GT Black Coupe- The beater
    1998 Grand prix GT Black coupe- Top swapped, XP cam
    2008 Grand prix Midnight blue- The slow but nice car
    1999 Chevrolet Silverado red ext. Cab
  3. #3 Re: 98 GTP smoking problems
    Nov 2011
    Laredo, TX
    It was already smoking so I changed both and it kept in smoking after but im out of ideas
  4. #4 Re: 98 GTP smoking problems
    Jul 2011
    Michigan
    maybe you have some bad rings or a chipped piston. do a compression test.
  5. #5 Re: 98 GTP smoking problems
    Charles City, IA
    Yeah do a compression and cylinder leakage test.
    SMGPFC Two Nipple General
  6. #6 Re: 98 GTP smoking problems
    And...first, I'd check that pcv. It can dump oil into the intake.
  1. Smoking is bad
    By Explicit_Spade in forum Off Topic Discussion
    Last Post: 09-12-2011, 07:57 PM
  2. Smoking in your car
    By Dobbs122 in forum Off Topic Discussion
    Last Post: 08-03-2011, 06:46 AM
  3. HID Ballist Smoking
    By fri3dchick3n in forum General Tech Discussion
    Last Post: 04-09-2011, 11:21 PM
  4. I'll have what he's smoking
    By gpgt04 in forum Off Topic Discussion
    Last Post: 08-11-2010, 01:12 AM
  5. Best way to quit smoking?
    By JESSEGOTTA GP GT in forum Off Topic Discussion
    Last Post: 02-20-2010, 10:39 PM
