Thread: Best gains for dropping $2000 into a GTP
Results 1 to 20 of 144
Threaded View
  1. #11 Re: Best gains for dropping $2000 into a GTP
    GT Level Member rmcardle3's Avatar
    Houston, TX
    4T65E Hardened 4th Clutch Shaft $64.95
    This is a new aftermarket 4th Clutch hub/shaft. The spines on the end are heat treated to prevent them from wearing and stripping out which is a very big problem in these transmissions and will cause no 4th gear. GM started using heat treated shafts around 2003, so if your trans is older it will not have this and is highly recommended to install during a rebuild.
    4T65E Upgraded Input Shaft $449.99
    The stock input shaft is pretty much the first major weak link in the 4T65E and once you reach roughly 300whp it is only a matter of time before it will break and leave you stranded. We sell and install Intense Racing input shafts which are rated to aprox 500+whp and are a vast improvement over the OE part. Not only are these input shafts thicker and made of a stronger material than the stock piece but also have many revisions throughout including improved O-ring groove, new lube diverter tube installed, reduced slop on sprocket splines, and improved oil feed holes. These shafts are manufactured with extremely high quality and finish and made by the same company who makes the GM Racing team input shafts for their race transmissions.
    4T65E 7/8" Single Chain Conversion Set $299.95
    The stock dual chain setup works great but once you start making power above roughly the 325whp mark and make frequent track passes, especially with slicks, they will fail and break which leaves you stranded. These single chain conversion kits use a Borg / Morse HyVo 7/8" chain and estimated ratings are 400-450 WHP depending on application.
    All from:
    http://www.tripleedgeperformance.com
    97-03 PONTIAC GRAND PRIX 3.8L 3-1 RACING HEADER EXHAUST
    speed_daddy ( 7806)
    99.4%
    add maybe an Intercooler, a modular pulley system with a 3.4 pulley and a Tune.
    OR
    Spend all of it on a Turbo Kit
    Then add this to get back to where you started...
    4T65E High Performance Street/Strip model
    Starting at $1649.95
    and then start at the top of the page and work your way down.
    Dave, (Trannyman95) if you are reading this how am I doing? lol.
  1. ZZP vs cam setup...Gains?
    By OrangeL67 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-15-2012, 11:18 PM
  2. Replies: 13
    Last Post: 04-12-2010, 08:45 PM
  3. N* gains
    By gtpsleeper in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-25-2009, 09:50 AM
  4. Easiest HP gains
    By mikes_comp_g in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-08-2008, 02:17 AM
  5. any gains in porting the boost bypass passage?
    By fst in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-18-2008, 10:59 AM
