Thread: Wierd tempature issues after replacing ECT sensor.
Results 1 to 4 of 4
  1. #1 Wierd tempature issues after replacing ECT sensor.
    SE Level Member FlaminWhite97GTP's Avatar
    Nov 2009
    Monee, IL
    Good news just got the ECT sensor replaced, but once it was replaced it. I was driving down the street & I notice the tempature starting flying up (it went over 210), but when I stopped at a stop sign it quickly went down to about 170. I cut the car off & immediately start it back up. Then I drove it home (about a 30 minute ride) the temperature read normal. The car was barely even running for 5 minutes when this happened.
    Second Time:
    I disconnected the battery, to reset the ECT code (I dont think he reset the battery) & it did the exact same thing again. I am confused, what could this be. Could it be the PCM recalibrating the tempature .. I am confused & worried lol. I checked the oil & it was still clean, but has a few small bubbles. Although I check it when the engine was warm
    176K Miles, Things Done: 25K Tranny, VC & LIM Gaskets Replaced, synthetic fluids all around.
    Mods to come: CAI, Headers, Roller Rockers, U-bend & DP Delete, etc
  2. #2 Re: Wierd tempature issues after replacing ECT sensor.
    Charles City, IA
    Was the coolant system bleed after the install? Are you low on coolant?
    SMGPFC Two Nipple General
  3. #3 Re: Wierd tempature issues after replacing ECT sensor.
    Banned - Busted For Scamming
    Feb 2009
    This is normal. The temperature normally rises to 210 area then the thermostat opens, and the temperature drops. Nothing to worry about.
  4. #4 Re: Wierd tempature issues after replacing ECT sensor.
    i pay to play badbrad's Avatar
    Dec 2008
    hueytown, alabama
    a tune that directly relates to ur t-stat will fix the 210* temp spike. (i.e. fans on at 185,,,somrthing like that) till that is fixed, your temp. ind. may be everywhere in the 180 to 210 range.
  1. WIERD!!! has this happened to anyone else?
    By aron2409 in forum General Tech Discussion
    Last Post: 11-25-2009, 01:34 AM
  2. ABS Speed Sensor Issues
    By foghelmut in forum General Tech Discussion
    Last Post: 10-05-2009, 09:08 AM
  3. 97 gp shifting wierd
    By Thut420 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-07-2009, 12:44 PM
  4. kr wierd issue
    By GTP4 in forum PCM Tuning
    Last Post: 02-18-2009, 08:20 AM
  5. Replacing a speed sensor, where are they located?
    By McCalley08 in forum General Tech Discussion
    Last Post: 01-24-2009, 04:17 AM
