Thread: heat spike
Results 1 to 20 of 31
  1. #1 heat spike
    GT Level Member undecided's Avatar
    taylors falls MN
    okay so i just did an ac delete on my car because the compressor broke.
    when i took it for a drive i did a launch from a dig and at about 90mph i noticed the engine temp was at 210 which is unusually high for my car.
    when i let off the temp dropped back down to about 180 in about 10 secs.
    when i pulled into the driveway i opened the hood and the headers where cherry red and glowing.
    my brother and friend took it for a drive immediatly after and it did not have the same problem.
    normally i would think is was a fluke but since the headers where glowing it worries me. any info?
    p.s. it was only one of the front three pipes. the one on the driver side
    any and all help would be appreciated
    thanks
    1998 white grand prix gtp - speed daddy headers & ported supercharger
    1982 z28 Camaro - all original with only 80k miles and rust free - slow as heck
  2. #2 Re: heat spike
    the glowing sounds like it'd be your cat.
    After doing that, I'd pull the plug and check to see how its doing.
  3. #3 Re: heat spike
    Donating Users kfish's Avatar
    Ohio
    it wouldnt be the cat if just one exhaust port was glowing. sounds like somethings goin on with the cylinder. but i agree pull the plug and check stuff out.
  4. #4 Re: heat spike
    GTX Level Member bronzemist02's Avatar
    Canada
    ^ I'd try that first too. Couldn't the thermostat do that too if it wasn't working at all because the fans wouldn't come on when they were supposed to? Fuse for the fans could do the same thing too if it was blown.
  5. #5 Re: heat spike
    Ohio
    if the thermostat was stuck shut, he would over heat big time. if it was stuck open it wouldn't ever get warm.
  6. #6 Re: heat spike
    its a $10-20 part that will probably have to be replaced anyways.
    If you want to test it, pull it and put it in a pot and boil the water and use a thermometer to confirm the open temp.
    Its slightly less time consuming to just replace it.
    When you're moving above say 50 KM/h, the cooling fans don't really all that much.
    Also, bleed the cooling system.
    Air pockets could have caused that.
  7. #7 Re: heat spike
    Canada
    Quote Originally Posted by kfish View Post
    Ok. Thanks. Just thought i'd ask because I wasn't quite sure about it and thought it may relate to this somehow. If the fans weren't coming on at all too the car would overheat fairly quickly when under that much stress too. He said he accelerated from a dig to 90mph (i'm assuming hard acceleration).
  8. #8 Re: heat spike
    the speed would have been enough to pull the temp down due to airflow through the rad,
    but that would only happen if hte t-stat was open, so i think its safe to assume its okay.
  9. #9 Re: heat spike
    Canada
    Ok. Didn't think of that. Thanks for helping me clarify some things.
  10. #10 Re: heat spike
    taylors falls MN
    thanks aton guys ill check those things out and inform ya if it works or not
  11. #11 Re: heat spike
    I live here. UR LOSN's Avatar
    Rockford, IL
    any updates? are any hoses close to the headers?
  12. #12 Re: heat spike
    i pay to play badbrad's Avatar
    Dec 2008
    hueytown, alabama
    when the a/c works your fan runs. u deleted the a/c so the fan may not be running. computer tells other fan to kick on around what 200*??? u need a tuner or tune to cut the fans on according to the t-stat..i believe i may be somewhat right.....i'd still check the cat/exhaust stuff to for sh!ts and giggles. almost blew up the mustang when the cat clogged... post resluts
  13. #13 Re: heat spike
    taylors falls MN
    the plugs are all clean but i think im gonna replace them soon anyways
    im back in my dorm room and the car is at home so i wont be able to do anything on it till this weekend
  14. #14 Re: heat spike
    Donating Users blowfishRus6's Avatar
    g.a.
    my fans dont turn on till 225* its winter time, dont really need the fans, and i dont consider 210 to be running hot at all. blocks like to be ran hot. there more efficent then.
    as far as your issuie, i dont really have a clue
    white 04 comg G gtp. wizair, pacesetters, slp 1.8 rr
    its slow.
  15. #15 Re: heat spike
    Dec 2008
    hueytown, alabama
    i would think the cat or an air pocket, but not plugs, oh well...
  16. #16 Re: heat spike
    g.a.
    air pockets will cause heat spikes like that.
    i just let the car get up to operating temps, crack the radiator cap for a few mins, let it bleed the air out, then cap it back up.
    you dont even need fans if you have a properly working coolent system. well maybe on a 100* day sittin in traffic, but even then it should not OVER heat, just run hot.
    its slow.
  17. #17 Re: heat spike
    Feb 2008
    San Diego, CA
    Glowing red exhaust manifold usually means either plugged cat (as said), running too-retarded timing or poor valve seating (allows unburnt fuel to combust in exhaust manifold), or running too lean (just gets too hot).
    As was said, since it's only one pipe, it's likely not a cat (or for that matter, timing) issue. I guess it could be a bad injector on that cylinder causing leanness, but then you said the problem went away?
    (Injectors can have intermittent issues, of course)
    And since it did "go away", it's probably not a valve issue.
    I'm with those who think it was an air pocket/bubble in the coolant jacket in the head, and it's probably OK (burped itself) now.
    But do burp it, keep an eye on it, and keep an eye on that cylinder's injector. If you see redness on that cyl again, switch injectors around and see if the problem follows.
  18. #18 Re: heat spike
    taylors falls MN
    thanks ill try that this weekend
  19. #19 Re: heat spike
    taylors falls MN
    hey did what you said and i havent had any problems since
    just thought id give an update if you were still wondering
  20. #20 Re: heat spike
    Dec 2008
    hueytown, alabama
    what did u do?????injecto??
  1. Low heat
    By citydriver in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-08-2010, 08:20 PM
  2. No Heat, Need Help.
    By speed24 in forum General Tech Discussion
    Last Post: 12-17-2009, 03:50 PM
  3. No Heat!
    By srspicer in forum General Tech Discussion
    Last Post: 10-25-2009, 11:55 PM
  4. Heat and A/C??
    By lorenzojay in forum General Tech Discussion
    Last Post: 09-28-2009, 08:43 PM
  5. No heat -- or very little
    By Teancum in forum General Tech Discussion
    Last Post: 03-27-2009, 07:55 AM
