Thread: 1997 Valve Covers*HELP*
Results 1 to 14 of 14
  1. #1 1997 Valve Covers*HELP*
    Kingsford
    I went ahead and started on my valve covers gasket replacement tonight and I can't get the front cover off... I also can't break the bolt that's holding the coil housing off so I dont see how there would be any other way to get this finished by tonight, I was only going for the front bank and doing the rear next week in class.. ideas?
    I need to get somthing done by tonight because I dont have any other way to get to work and I didn't think this would be this bad ...
    Chi_Town
  2. #2 Re: 1997 Valve Covers*HELP*
    Use lube like WD 40, PB blaster, or some penetrating oil. Then try harder.
    Bah, the rear one is worse.
    Alt, belt tensioner, EGR bracket, and fuel rail in my case since i didn't have a magical wrench.
  3. #3 Re: 1997 Valve Covers*HELP*
    Kingsford
    But i can't seem to get to the actual nut on the bolt itself.... and when i try to unbolt it from the end of that bolt it strips the threads off the tip....
    idea?
    And, iv heard that from alot of people that the rears are a pain to do.. Which is why im gonna hopfully get the fronts done and get the rear done asap (mainly need time)
    Chi_Town
  4. #4 Re: 1997 Valve Covers*HELP*
    Sure you have the correct size wrench/socket? If you didn't, you'd strip it/round it off. Neither are good. It's metric by the way...
  5. #5 Re: 1997 Valve Covers*HELP*
    Donating Users blowfishRus6's Avatar
    g.a.
    yea i dident have much of an issuie, get the right size socket and eat more wheeties
    just an fyi for the back valve cover, for the alt. bracket, make sure you dont put the long bolt in the hole that goes over the valve cover, if so that bolt is long enough to go down into the valve cover once tightened and put a nice little hole in the valve cover. just an fyi........
    white 04 comg G gtp. wizair, pacesetters, slp 1.8 rr
    its slow.
  6. #6 Re: 1997 Valve Covers*HELP*
    GTX Level Member Rather B Blown's Avatar
    Dec 2008
    London, Ontario
    you need a deep, deep socket...none of my sockets were long enough except for my 5/8 spark plug socket..it was a little loose on the bolt, but still worked fine and didnt strip it.
    Quote Originally Posted by Reptile
    It sounds like you accidentally stuffed a midget in the downpipe, and he's hammering out an SOS to get out.
  7. #7 Re: 1997 Valve Covers*HELP*
    Donating Users kfish's Avatar
    Ohio
    i used a super long 15mm socket on a 1/2" drive ratchet.
  8. #8 Re: 1997 Valve Covers*HELP*
    Charles City, IA
    Slide the socket on the stud first with out the ratchet on it, then attach the ratchet to the socket, it will not go all the way in the socket, but it will let you turn it and get the nut off.
    SMGPFC Two Nipple General
  9. #9 Re: 1997 Valve Covers*HELP*
    Kingsford
    Thanks everyone for all the help.. Got the job done on the front valve cover.. I'll start on the rear in a week or so since I need my car .
    Chi_Town
  10. #10 Re: 1997 Valve Covers*HELP*
    Banned - Busted For Scamming
    Feb 2009
    Just an fyi, its not a 10mm head, a 3/8" deep socket fits much better, 6 point of course. For the valve cover bolts.
  11. #11 Re: 1997 Valve Covers*HELP*
    Charles City, IA
    Yup every other damn bolt on the car is a 10 tho.
  12. #12 Re: 1997 Valve Covers*HELP*
    Kingsford
    I used a 10m =(
  13. #13 Re: 1997 Valve Covers*HELP*
    Ohio
    rocker bolts are 3/8" as well....weird ass gm
  14. #14 Re: 1997 Valve Covers*HELP*
    Charles City, IA
    Mine are hex screws.
  1. Smooth Valve Covers
    By stlmo_gtp in forum How To Write-Ups/Tech Tips
    Last Post: 01-19-2012, 02:03 PM
  2. 3800 Valve covers
    By Sonny in forum Shops and Community Heroes
    Last Post: 12-09-2009, 07:10 PM
  3. zzp valve covers
    By rodman in forum Turbo
    Last Post: 08-30-2009, 04:20 PM
