Thread: Still Knockin'
Results 1 to 11 of 11
  1. #1 Still Knockin'
    SE Level Member 2001GTP's Avatar
    Apr 2009
    Phoenix, AZ
    Got my MPS 3.6" pulley from ZZP today. Threw it on and went for a run. Surprise, surprise, I'm seein about 1* of KR. ! Mods are in my sig. I guess I'm gonna try some ssac headers next. If that doesn't cure it, I'm gonna start a L32 build and go from there!
    3.6", 3" Downpipe, K&N CAI, 104's, PRJ Tune, P-Log, 180 t-stat,Res delete, wideband, boost gauge. 14.11" @ 99.5
  2. #2 Re: Still Knockin'
    Charles City, IA
    Maybe excess carbon on the pistons making hot spots.
    SMGPFC Two Nipple General
  3. #3 Re: Still Knockin'
    Apr 2009
    Phoenix, AZ
    How do I cure that?
  4. #4 Re: Still Knockin'
    Charles City, IA
    Quote Originally Posted by 2001GTP View Post
    How do I cure that?
    Have you ever sea foamed your car?
  5. #5 Re: Still Knockin'
    Apr 2009
    Phoenix, AZ
    Yes sir. Fed it in through the brake booster hose.
  6. #6 Re: Still Knockin'
    in a house
    I would bet its just climate related. How cold is it there? 1* is not that bad.
  7. #7 Re: Still Knockin'
    Apr 2009
    Phoenix, AZ
    42* F.
  8. #8 Re: Still Knockin'
    in a house
    You probably won't see any when it gets a warmer but def get the headers, they will help a ton
  9. #9 Re: Still Knockin'
    Portland Oregon
    How many miles on your plugs? Could be time for replacement. Check the gap
  10. #10 Re: Still Knockin'
    What's your trims look like? Maybe you have a bad injector/fuel filter or something...just a thought. Also...is your sway bar flipped? Could be false knock...
  11. #11 Re: Still Knockin'
    Apr 2009
    Phoenix, AZ
    LTFT's look good at 0 to -2. 11.3 on the wideband @WOT. Running 12* of timing. KR goes away with racing fuel and 3.8 pulley. Plugs are about 10,000 miles old, gapped at .054. Could a wider gap help out at all?
    edit: went and goofed around alittle tonight. 2 to 2.4 KR when I shift with 10 lbs of boost. Maybe new rockers would help her breath a bit.
  1. 3.4 is on! belt slip solved still knockin :)
    Last Post: 08-08-2009, 03:31 AM
