Thread: HID Headlights, not sure!
Results 1 to 12 of 12
  1. #1 HID Headlights, not sure!
    SE Level Member jjwalton77's Avatar
    Jul 2008
    Ames, IA
    Hello, im going to buy some new HID headlights for my 98 gtp. Im looking for a very deep blue color and with the research ive done, the 10000k lights seem to be the bluest. But im just not sure if i have to buy an entire HID kit, to have these headlights work. And i am also going to change my fog lights to the same thing, would i need to buy 2 HID kits then? Can someone just explain what i need for 10,000k headlights and foglights to work properly. thanks
  2. #2 Re: HID Headlights, not sure!
    GTX Level Member killakross5o4's Avatar
    illinois
    8k is what i got..very nice
    Shortstack Intercooler, 1.9 Rockers, 3.2 pulley,180 drilled T stat,103 plugs, U bend delete with no cat, thrush resinator,3inch pace setter cat back,shift kit,ZZP Chrome tips,,ZZP stage 2 throttle body,homemade 4 inch CAI,DHP tuned PCM,SSAC headers
  3. #3 Re: HID Headlights, not sure!
    illinois
    ebay sales the whole kit for less then 50 bucks....and yes u would need 2 kits..one for head light one for fog lights
  4. #4 Re: HID Headlights, not sure!
    swift current,sask.
    For starters you will need 2 kits then, I think if you get the good kit they should come with relays that will take the load off of the headlight circuit. From what i know the 10000k is going to be a good choice for blue, if you go any higher it will start to be a purplish light.
  5. #5 Re: HID Headlights, not sure!
    the kelvin rating on all the bulbs is pretty much an opinion. its SUPPOSED to be this:
    4300K - bright white
    6000K - ice blue
    8000K - blue, getting towards purple
    10000K - purple/pink
    i ran 6000K HID bulbs and they looked ice blue, which i liked. the higher the kelvin rating, the lower light output youll get.
  6. #6 Re: HID Headlights, not sure!
    SE Level Member cincygoat's Avatar
    Apr 2009
    Amelia
    some one told me recently that in order to get a more controlled beam with HID bulbs you have to have a lens for them to shine through other wise its just scattered light is this true
  7. #7 Re: HID Headlights, not sure!
    illinois
    no....
  8. #8 Re: HID Headlights, not sure!
    Apr 2009
    Amelia
    ok the next thing I heard was that the 55w are overkill and the 35s work great also
    DDM HID Kit Slim Ballast (35W or 55W): DDM Tuning - HID Kits, DEPO Lights, BMW Bumpers & Lighting
    My friend has these on his Eclipse but I have never heard of them any opinions would be nice. The one thing I do like is the Lifetime Warranty
  9. #9 Re: HID Headlights, not sure!
    illinois
    yaaaaaaaaa
  10. #10 Re: HID Headlights, not sure!
    Dec 2008
    Lawndale, CA
    DDM makes a good kit. I installed a set on my brothers motorcycle and on his friends motorcycle. They have ahd no issues. The 35W kit is all you really need. That provides enough light. I usually run a relay harness with HIDs. The DDM bi-xenon kit might come with one. You will definitely need one if you aer going to get the 55W kit.
  11. #11 Re: HID Headlights, not sure!
    Oct 2008
    Calgary, Alberta
    Currently I have 35 w projector hid fog lights (blazer brand, sharp cutoff) that outperform the oem headlights, I would like better headlights But I wont use hid ion them until I have time to retrofit oem projectors from a car that came with HID.
  12. #12 Re: HID Headlights, not sure!
    Jul 2008
    Ames, IA
    im thinking about going with the blue tinted halogen lights, even though they may not be as bright, there cheaper and easier to put on. anyone got any good brands they know of?
  1. my new headlights!!!!!
    By superv6 in forum Visual/Body Modifications
    Last Post: 09-10-2009, 03:03 PM
  2. Gtp headlights always on?
    By kw00GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-10-2009, 02:44 AM
  3. headlights
    By smittrailfire in forum General Tech Discussion
    Last Post: 04-11-2009, 03:20 PM
  4. New headlights.
    By Egleone6 in forum Visual/Body Modifications
    Last Post: 09-14-2008, 05:42 PM
