Thread: 97-03 gtp air/fuel ratio gauge
Results 1 to 9 of 9
  1. #1 97-03 gtp air/fuel ratio gauge
    GTX Level Member a98gtp4u's Avatar
    GEORGIA
    does any1 know where i hook up the signal wire?
    3.4 pulley, 3" catless dp (ubend deleted), 3" exhaust split to 2.5 dynomax mufflers (no res), zzp plog, 4" spectre intake, alt rewire, under/overdrive pulleys, intense pcm, 3/4" zzp tb spacer, al 104's, 180* stat, msd coils/8.5mm wires, heatwrapped crossover, flipped db's, optima red top, sunpro st boost gauge: boosting 11lbs.
  2. #2 Re: 97-03 gtp air/fuel ratio gauge
    Donating Users kfish's Avatar
    Ohio
    dont even put it in unless its a wideband. my narrowband pulled enough voltage from the signal wire that it was screwing with my fuel trims. unhooked the guage and presto.
  3. #3 Re: 97-03 gtp air/fuel ratio gauge
    GTP Level Member lambokit's Avatar
    Apr 2009
    Radford, Virginia
    I think the question still stands. Where to hook up the signal wire????
    Lambokit to be built!!!!!
  4. #4 Re: 97-03 gtp air/fuel ratio gauge
    Charles City, IA
    Does it say to hook in to the high signal or the low signal wire. High=purple Low=tan
    SMGPFC Two Nipple General
  5. #5 Re: 97-03 gtp air/fuel ratio gauge
    Jersey
    it goes into the purple.
    Yay for a light show!!!
    16' wrx sti- stock
  6. #6 Re: 97-03 gtp air/fuel ratio gauge
    GTP Level Member JoshMcMadMac's Avatar
    Waynesboro, PA
    Quote Originally Posted by a98gtp4u View Post
    Anywhere you want...the output is useless.
    2000 NavyBlueMetallic GTP Coupe
    HPTuners / Intercooler / Devil's Own Meth / 1.8 SLP Rockers / 3.1-3.3" / 180° / TB Shield / FWI / PLOG / Jimmy-C Downpipe / U-Bend Delete / Mark VIII Fan / Alt. rewire / FP rewire / F-Body Brakes / Buick Strut Braces / SLP Tips / 20% Tint
  7. #7 Re: 97-03 gtp air/fuel ratio gauge
    Donating Users JDCMoney's Avatar
    Middleboro, Ma
    Purple wire on the o2 sensor before the Cat
    1998 Blue Raspberry Slushy Metallic GTP: The Daily currently has 185k+
    1989 Sierra:
    Weekend Warrior 1997 Regal GS: Stock For Sale 2000 GTP: Parts Car
  8. #8 Re: 97-03 gtp air/fuel ratio gauge
    purple wire, but you should really just leave it off. its seriously a waste of a gauge.
  9. #9 Re: 97-03 gtp air/fuel ratio gauge
    Ohio
    the only way to truely use an afr gauge is to wire it into a completely seperate o2 sensor, or if your not running a cat, wire it to the rear one, and get a wideband. if you get a narrowband and hook it to the front 02 sensor youll seriously never get it tuned. itll pull enough voltage from the signal to the pcm that it will whack out all your fuel trims. its a tuning nightmare plain and simple.
  1. Fuel Gauge
    By racecardude310 in forum General Tech Discussion
    Last Post: 01-22-2010, 04:56 AM
  2. Air Fuel Ratio
    By rolyat in forum General Tech Discussion
    Last Post: 01-12-2010, 08:17 AM
  3. air fuel ratio ?
    By eddie97gt in forum General Tech Discussion
    Last Post: 02-17-2009, 05:46 PM
  4. 00 GT Fuel Gauge
    By cherm45 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-13-2009, 05:50 PM
  5. what is my differential ratio, and first gear ratio?
    By 2000GTP in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-07-2008, 09:31 AM
