Thread: Gtp headlights always on?
Results 1 to 11 of 11
  1. #1 Gtp headlights always on?
    Kitchener
    hello all i am new to the GTP scene, formely of the mustang and jeep scene..
    have a 2000 gtp and headlights are always on. need help with basic wiring
  2. #2 Re: Gtp headlights always on?
    they are always on with all GM cars. its called DRLs (daytime running lights). you need to disable them.
  3. #3 Re: Gtp headlights always on?
    GT Level Member skidoojames151's Avatar
    seattle
    why would you disable them? unless you are running HID's there is no logical reason to do this..
  4. #4 Re: Gtp headlights always on?
    Wausau, WI
    some people want to have them off.....it is that simple.
  5. #5 Re: Gtp headlights always on?
    i think it looks better to not have headlights on during the day as well as it saves on bulb life.
  6. #6 Re: Gtp headlights always on?
    SE Level Member GTP00Matt's Avatar
    May 2008
    Delavan, MN
    Personally i like being able to run just my running lights and fog's when the headlights arn't needed.
    2000 GTP coupe, totally stock
    1995 Chevy K2500 6.5 TD 4" straight pipe 285 BFG's on 16x8 American Racing Nitro's
  7. #7 Re: Gtp headlights always on?
    TN
    I have a cure for u if u dont mind me.Go to zzp.com look up Day Running Light Switch they are 18.00 but shiping is high so good luck.
    P.Sthere r many ways of connecting wires u may want to use a different way from the installation paper
  8. #8 Re: Gtp headlights always on?
    How about save that money and just unplug them behind the dash? Last I checked that is FREE.
  9. #9 Re: Gtp headlights always on?
    Moreno Valley, CA
    You can disable the daytime running lights via your information center (computer in dash) Personally, I leave the option turned on for my wife who is button challenged anyway for the following reasons. Lights are set to automatic so they come on at night or when too dark. Lights are required in California when it's raining so wife doesn't have to remember to turn them on. Some two lane roads through mountains, forests, etc. have posted a "Daytime Headlights Required", so don't have to think about it. Also, the daytime lights do not affect the dash lights, so you can see the radio, clock, info center, etc. during the day.
    And of course I want people to see me coming, especially if I'm running between 100 and 140. Yes, my little factory 3800 GT w/SC will go that fast, I would just feel better about it if it was rear wheel drive instead.
  10. #10 Re: Gtp headlights always on?
    Wausau, WI
    Quote Originally Posted by Subwarrior632 View Post
    It depends, obviously your car is of the 04 or newer vintage, you do not have the option of adjusting the DRL's pre-04.
  11. #11 Re: Gtp headlights always on?
    Jan 2009
    Michigan
    wow.... did that help you op?
    you can unplug the drl fuse in the glove box
  1. HELP I need better headlights for my 02 gp
    By logands in forum Visual/Body Modifications
    Last Post: 11-04-2008, 10:07 PM
  2. Headlights
    By BankRupt in forum General Tech Discussion
    Last Post: 04-21-2008, 11:04 PM
