Thread: L.I.M. gasket replacement \ alternator bracket
Results 1 to 16 of 16
  1. #1 L.I.M. gasket replacement \ alternator bracket
    northeast
    Backstory:
    I am in the process of a LIM gasket replacement on a '98 GTP. Long story short I was going to sell it for parts because it would not pass inspection and I did not want to put any money into it. After seeing the LIM in 33 minutes video on this forum i figure it was worth a shot to try. relatively inexpensive parts and learn a good deal in the process.
    So every little process on this procedure has been way more troublesome that it should be. Vehicle was obviously not cared for very well.
    Problem
    Today I hit a major snag. Removing the alternator bracket the bottom coolant connection to the engine sheared off in the hole. I had thought this was a plastic connection like the elbow above, but after inspection it appears it is actually part of the bracket and now there is a ring of steel/aluminum in the engine side orifice.
    Is there an easy solution to this problem. Or is it time to say enough is enough and call the junkyard to take it away?
    I can add pics tomorrow to show exactly what happened.
  2. #2 Re: L.I.M. gasket replacement \ alternator bracket
    GT Level Member rolyat's Avatar
    OKC
    I don't really know what you're trying to say but both of the elbows are plastic. One broke off when I did mine and a screwdriver was all i used to get it out. Just buy new plastic elbows, they're like $4.
  3. #3 Re: L.I.M. gasket replacement \ alternator bracket
    Charles City, IA
    Yeah they are both plastic.
    SMGPFC Two Nipple General
  4. #4 Re: L.I.M. gasket replacement \ alternator bracket
    northeast
    PICS:
    That is plastic??
    I have extra plastic elbows, but the elbow here is part of the bracket.
  5. #5 Re: L.I.M. gasket replacement \ alternator bracket
    Charles City, IA
    no pic
  6. #6 Re: L.I.M. gasket replacement \ alternator bracket
    northeast
    fixed the links.
  7. #7 Re: L.I.M. gasket replacement \ alternator bracket
    northeast
    any suggestions for removing the piece out of the engine side?
  8. #8 Re: L.I.M. gasket replacement \ alternator bracket
    Nov 2008
    norman oklahoma
    just git one from pull a part. your model does have metal on bottom, never seen one break, but i sure other guys here have seen it . i would definitely fix it. it will be worth it. you will have more money in your pocket
  9. #9 Re: L.I.M. gasket replacement \ alternator bracket
    Nov 2008
    norman oklahoma
    try a pick, or a gutter spike, the spike head should insert and be able to grab the lip inside
  10. #10 Re: L.I.M. gasket replacement \ alternator bracket
    Charles City, IA
    Strong pick and some penetrating fluid.
  11. #11 Re: L.I.M. gasket replacement \ alternator bracket
    GT Level Member Joe m's Avatar
    mesa,az
    ^x2 or bu the bracket from a junk yard and save yourself the trouble. also if you have it off the car. take a screwdriver or something with a hammer and try to split it in half. things like that happen on old 350's with the heater hose going into the back of the intake manifold. iv always used the screwdriver and hammer method to split it then pull it out. pretty simple.
  12. #12 Re: L.I.M. gasket replacement \ alternator bracket
    Nov 2008
    norman oklahoma
    so how about a update did you get broken piece out
  13. #13 Re: L.I.M. gasket replacement \ alternator bracket
    northeast
    YES! came out rather easy actually. Got it good with PB Blaster & then pried it out with a screw driver. Thanks for the tips.
    Is the newer bracket (with the 2 plastic elbows) fully compatible with my engine?
    Now I can't seem to remove the LIM. Stuck on the side opposite the drive belts. Are there any hidden bolts over there?
  14. #14 Re: L.I.M. gasket replacement \ alternator bracket
    SE Level Member viroid's Avatar
    Catlett, VA
    There is a bolt hidden down in one of the channels on the front-right side, mine was covered in gunk, dirt, and pieces of acorn shells. It's just left of the thermostat port.
  15. #15 Re: L.I.M. gasket replacement \ alternator bracket
    northeast
    Yep thats the one. I found it sunday, buried under a mountain of gunk and dead leaves.
  16. #16 Re: L.I.M. gasket replacement \ alternator bracket
    i pay to play badbrad's Avatar
    Dec 2008
    hueytown, alabama
    are u done yet? got it running?
  1. Valve cover gasket replacement
    By Burgundyman in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-15-2010, 07:06 AM
  2. engine not firing after UIM and LIM gasket replacement
    By Dericm02 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-03-2009, 02:30 AM
  3. Intake Gasket Replacement
    By wicked50 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-27-2009, 06:21 PM
  4. Oil Pan Gasket Replacement
    By Metallistar in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-19-2008, 01:18 PM
