Thread: Intake Gasket Replacement
Results 1 to 15 of 15
  1. #1 Intake Gasket Replacement
    Jan 2009
    Peoria
    Noticed a little puddle of coolant on my intake of my 2000 supercharged Grand Prix. Decided to tear it down. Noticed the base gasket for the supercharger was probably leaking coolant. I'm going to upgrade the lower intake gaskets also. I have part numbers for the aluminum based gasket from 89017816 to x23-104-B6 to 89017825. The 89017825 is in stock locally, so I'm going to check it out today. Wondering if there is an aluminum supercharger base gasket also?
  2. #2 Re: Intake Gasket Replacement
    TDCRacing
    Guest
    Quote Originally Posted by wicked50 View Post
    Nope, Nothing available. Just get the regular fel-pro's. There like 8.99 a peice I think? It also would not hurt to use a little rtv around the base of the s/c and LIM but it is not a must. Also replace the coolant o-rings they are cheap. Don't try to reuse them.
  3. #3 Re: Intake Gasket Replacement
    Jan 2009
    Peoria
    I aready bought the FEL-PRO's. The supercharger gasket has the yellow O-rings in the package with it. Good to know that nothing better is available, so I'll use that. The 89017825 the base I'd want? I've been digging around and found three different part #'s for this improvement.
  4. #4 Re: Intake Gasket Replacement
    TDCRacing
    Guest
    89017824 are the ones you want. Thanks Brian (reptile) for the number.
  5. #5 Re: Intake Gasket Replacement
    the stock ones are better than the "genV gaskets" that are made out of that garlock crap. yeah, you can reuse them but they suck all kinds of ass to seal.
  6. #6 Re: Intake Gasket Replacement
    TDCRacing
    Guest
    X24
  7. #7 Re: Intake Gasket Replacement
    Jan 2009
    Peoria
    Quote Originally Posted by TDCRacing View Post
    Okay, they sold me the 89017825 and they look right. Not to be a PITA, but what's the difference? The 824 not pinned?
  8. #8 Re: Intake Gasket Replacement
    Jan 2009
    Peoria
    The plastic ones are better than the aluminum I just bought?
  9. #9 Re: Intake Gasket Replacement
    TDCRacing
    Guest
    Is that the part number for the plastic ones? i'm sorry. The aluminum ones are the better ones. So i'm guessing that was the difference.
  10. #10 Re: Intake Gasket Replacement
    i was talking about the supercharger gasket.
    the alumium lower intake gaskets (that are grey/sea foam green and not black/orange) are the better ones.
  11. #11 Re: Intake Gasket Replacement
    TDCRacing
    Guest
    Right. I knew that.
  12. #12 Re: Intake Gasket Replacement
    GTP Level Member Scimmia's Avatar
    QCA, IA
    As far as pinned vs not pinned, some of the 97 and older blocks didn't have holes for locating pins for the end gaskets. The pinned gaskets will still work fine, though, as there's just nothing in that area so they just hang there. As long as you got the aluminum framed gaskets, you should be fine.
    2001 Buick Regal LS - Almost Stock
  13. #13 Re: Intake Gasket Replacement
    Moore, Oklahoma
    I've actully had a very good experiance with the GEN 5 S/C gaskets. There made better than the garlocks. I'm pleased with mine so far
    Garlocks just suck ass period. No gasket is better than a damn garlock.
    And...
    Aluminum L32 LIM gaskets for the FTMFW!
    Shawn W. Larsen
  14. #14 Re: Intake Gasket Replacement
    Barksdale AFB, LA
    Here's a picture of the aluminum gaskets:
    2009 Subaru Impreza WRX STI
  15. #15 Re: Intake Gasket Replacement
    Jan 2009
    Peoria
    Exactly what I put in. Just finished everything up today. Had to jack the pass side of the car up to bleed off the antifreeze through the thermostat housing bleeder. Oh yea, I wish I'd known it's easier to get the filter off through the wheel opening. I changed the oil in the supergharger. Who designed those crappy plastic coolant tubes anyway. I know my way around in there now. Hopefully everything stays nice and dryoutside the block.
  1. Replies: 84
    Last Post: 09-09-2015, 08:10 PM
  2. Valve cover gasket replacement
    By Burgundyman in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-15-2010, 07:06 AM
  3. Intake Manifold Gasket/seal
    By ssm90GT in forum General Tech Discussion
    Last Post: 12-12-2009, 03:06 AM
  4. Intake manifold gasket
    By rudyram118 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-09-2008, 09:38 PM
  5. Oil Pan Gasket Replacement
    By Metallistar in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-19-2008, 01:18 PM
