I just got done replacing the upper and lower intake gaskets, upper plenum, thermostate, and valve cover gaskets after the engine was hydrolocked. Got everything put back together, put new oil in, and went to start the car and it is not firing. It turns over, acts like it wants to start, but still no fire. Everything worked just fine before. I replaced the spark plugs a couple months ago, so i made sure they were clean before putting back in, i have fuel pressure. the spark plug wires are in the correct order on the cylinders as well.....any ideas on why its not firing. Its turning over quick with good power from the battery.
