Thread: Heavy Clack Internal Front?
Results 1 to 11 of 11
  1. #1 Heavy Clack Internal Front?
    Australia Victoria
    Hey All,
    What A great engine & supercharger set up!
    I have put 1.8 hi ratio rocker & thinner push rods(as they were hitting web inside head), 3 Inch pulley, bigger throttle & Maf, water to air intercooler & 98 octane fuel!
    I have had a bad knock in the valve train system(since I found push rods were fouling on webbing inside head), I have since replaced the push rods(didn't fix), replaced the lifters with ZZP OE(not OE-r too noisey)!
    The oil pressure is fine 65Psi cold 60 Psi warm both at idle(goes to around 70 Psi over 2,000 rpm)
    When I had the valley off I felt the balance shaft & it has a little movement(by hand) & when I moved it there was a slight clack noise.
    It is from the front of the motor, when driving it, it gets better the higher rev's & then on decel it sounds like a light clattering & then when it goes back to idle it comes to a heavier clack!
    Any advise would be great!
    Cheers all Grant
  2. #2 Re: Heavy Clack Internal Front?
    Donating Users kfish's Avatar
    Ohio
    check the flywheel. mine was cracked and sounded just like valvetrain noise.
  3. #3 Re: Heavy Clack Internal Front?
    Charles City, IA
    Have fun blowing your car up.
    SMGPFC Two Nipple General
  4. #4 Re: Heavy Clack Internal Front?
    Donating Users ninnyGTP's Avatar
    Nov 2008
    Moreno Valley, California
    x2 on that one
    98 Grand Prix GTP L32, GenV, n*, 3.2", 1.9 rr's, 3.29 gears. All that jazz SOLD
    99 Mustang GT Steeda UDPs, 3.73s, Pypes O/R xpipe, Accufab plenum, Steeda CAI, B&M ripper, MHS s2 cams, 10.5:1 compression (290whp/310wtq) SOLD
    01 SVT Cobra #3654, B&M Ripper, K&N FIPK2, MAC O/R xpipe
  5. #5 Re: Heavy Clack Internal Front?
    Australia Victoria
    I don't think it is the flywheel, I just put a new solid plate flywheel on it as it is a manual & it did have a dual mass flywheel.
    Why will I blow it up?
    I forgot to mention, all the compressions are between 160 & 175 between all 6 cylinders!
    When I have been driving it on the road & the dyno hasn't had an ounce of knock(but KR is thru the roof due to noises in the motor)!
    Any other ideas would be appreciated, I'm thinking it might be in the timing chain area but this doesn't make sense to me as the noise like cam/cylinder speed not crank/cylinder speed!
    Also if anyone wants to know an easy way to change the rear rotor pack bearings let me know, I struggled for hours first before trying something simple & a lot neater!
  6. #6 Re: Heavy Clack Internal Front?
    Charles City, IA
    You are going to blow it up because you have no flow mods and a 3" pulley
  7. #7 Re: Heavy Clack Internal Front?
    utah
    click click boom
  8. #8 Re: Heavy Clack Internal Front?
    Australia Victoria
    Flow mods as in?
    I have ported charger, ported manifold & extractors & twin 2.5" system, is that what you mean?
  9. #9 Re: Heavy Clack Internal Front?
    Charles City, IA
    I mean you have no idea what you are doing and need to read. Your 2.5" twin system does nothing for flow.
  10. #10 Re: Heavy Clack Internal Front?
    GTX Level Member Rather B Blown's Avatar
    Dec 2008
    London, Ontario
    you need headers....seriously. now.
    Quote Originally Posted by Reptile
    It sounds like you accidentally stuffed a midget in the downpipe, and he's hammering out an SOS to get out.
  11. #11 Re: Heavy Clack Internal Front?
    Australia Victoria
    Sorry headers are extractors aren't they?
    I have pacemaker extractor's, so 2.5" won't flow enough for 17 PSI, the max it has boosted is around 15 PSI, I will get a smaller pulley for it anyway but I just want to find out what the noise could be?
    Any advise apart from flow issues?
  1. Proper INTERNAL PRNDL switch alignment pic
    By Trannyman95 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-12-2017, 04:55 AM
  2. internal mods
    By kjohnson in forum Visual/Body Modifications
    Last Post: 01-27-2010, 10:36 AM
  3. Motorcycle jack usefull for internal work?
    By PWNED in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-17-2008, 12:55 PM
  4. Internal Trans Parts that Are Questionable
    By JJ91284 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-19-2008, 12:36 AM
