Thread: P0172 and P0420 Codes
Results 1 to 6 of 6
  1. #1 P0172 and P0420 Codes
    Florida
    Recently I popped two SES codes, a P0172-Fuel Trim Bank One Condition
    and a P0420-Catalyst Effeciency Low-Bank one.
    I know that the P0420 is a common code to pull with a High flow cat, which I do have.(ZZP 3" DP with highflow cat)
    But I'm not sure what the P0172 code would be, from what I've read it seems to be subject to:Fuel injectors or O2 sensors.
    After looking around, my thoughts are that, because the Cat. is high flow, it's not reducing the emissions as much as the PCM(stock) is set to accept. Because of that, the rear 02 sensor is reading a rich condition setting the lights.
    Again I'm not too sure if that's the case, just seems it could very well be.
    Any input would be great.
    History:
    The Cat is about 6months old, same as the downstream O2sensor.
    The Upstream O2 sensor is about 1.5 years old.
    These codes only came up after I installed a 3.4" modular pulley this winter, but I drove the car over 2000miles before a light came on after the pulley swap.
    My injectors are rather noisy, but I have cleaned them (this summer.)
    Fuel pressure is fine, and theres no smell of raw gas, and the exhaust doesn't smell rich, just some residue on the tips.
  2. #2 Re: P0172 and P0420 Codes
    Charles City, IA
    The cat code is making you run rich setting the other code.
    SMGPFC Two Nipple General
  3. #3 Re: P0172 and P0420 Codes
    Florida
    That's my thoughts, now, if I install my spare Emulator, curing the P0420, it should cure the P0172 that the car is trying to compensate for, correct?
  4. #4 Re: P0172 and P0420 Codes
    Charles City, IA
    Yeah it worked for me.
  5. #5 Re: P0172 and P0420 Codes
    Florida
    Thanks a ton 01GTP, I'll put my Emulator on in the morning and post some results after some driving
  6. #6 Re: P0172 and P0420 Codes
    Florida
    After some "colorful" driving for over an hour with the Emulator in, I have not gotten any SES lights, so hopefully that solved that, the car also idle's better now.
    Thanks 01GTP
  1. P0420 code
    By BChimo in forum General Tech Discussion
    Last Post: 10-18-2012, 12:18 PM
  2. p0420 02 gtp
    By gtpinsc in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-05-2009, 10:52 AM
  3. p0172
    By awsom83 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-19-2009, 08:00 AM
  4. P0420 Code keeps setting on 2001 GTP
    By Littlegiant in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-06-2008, 07:50 PM
  5. p0420 code on
    By fst in forum General Tech Discussion
    Last Post: 01-05-2008, 04:19 PM
