Thread: What would i have to do to safely run a 3.0 inch pulley?
Results 1 to 20 of 29
  1. #1 Re: What would i have to do to safely run a 3.0 inch pulley?
    GrandPrix Junkie FastKatt's Avatar
    Feb 2008
    Rkrd, IL
    Quote Originally Posted by IndeedSS View Post
    You WB tune? A 3.2 on a GEN V, with no cam, rockers or IC is impressive, if you have no knock and are running a decent AFR. Times look very good too.
    No, I want to get a WB soon
    I am going to get a Dyno Pull 4/12/08, I will be posting the sheet & video
    Quote Originally Posted by GeddyLee View Post
    If that stands............ can you say "factory freak?"
    I would say get Trannyman to get your stuff tuned up. And good luck with the 12's.
    I would guess if you had a different DP at least it would free up some more HP for ya. Also are you running the stock airbox on your car? You might wanna consider that to allow a bit more air and cooler air into the system.
    Just a thought
    You saying I'm lying???
    What would Trannyman "tune up"? I have a PowrTuner...
    Did you click my mods list in my sig? I have PaceSetters, they come with a DP...
    I'm running a DIYS FWI
    Quote Originally Posted by TDCRacing View Post
    got any kr?
    With the 3.4, maybe a blip or 2 of 1-2deg
    With the 3.2, I had 2-3deg at the top of the gears then...
    Now 3.4 I see maybe 4 lines in 20,000 with under 1deg
    No trees were destroyed for this message.
    However, a great number of pixels were extremely inconvenienced.
    2004 Grand Prix Comp-G GTP Mod List - MySpace
  2. #2 Re: What would i have to do to safely run a 3.0 inch pulley?
    St. Louis Mo.
    Quote Originally Posted by FastKatt View Post
    Nope wasn't saying that. I thought I had read that you had only a few options hence me saying what I said. I might have seen someone else's profile or listing of their mods.
    I never clicked on your profile to see what you ACTUALLY HAD, my error again.
    Sorry
    James Shafer
    St. Louis MO
  1. Installing 6 1/2 Inch Front Speakers [*]
    By webracin in forum How To Write-Ups/Tech Tips
    Last Post: 04-28-2012, 11:45 PM
  2. What pulley and plugs to get??
    By TDCRacing in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-21-2008, 12:04 PM
  3. Pulley Puller
    By SyntheticShield in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-11-2008, 02:52 PM
