Thread: What would i have to do to safely run a 3.0 inch pulley?
Results 1 to 20 of 29
  1. #1 Re: What would i have to do to safely run a 3.0 inch pulley?
    GrandPrix Junkie FastKatt's Avatar
    Feb 2008
    Rkrd, IL
    I have a MPS from ZZP (3.4 & 3.2)
    On Slicks, last fall I ran a 13.274 1/4m with the 3.2 pulley and STOCK Timing...
    No Cam, No Rockers, No IC!
    I believe with the tuning I've done since, I should be in the high 12s with the same mods
    HTH
    No trees were destroyed for this message.
    However, a great number of pixels were extremely inconvenienced.
    2004 Grand Prix Comp-G GTP Mod List - MySpace
  2. #2 Re: What would i have to do to safely run a 3.0 inch pulley?
    SS-DD Level Member IndeedSS's Avatar
    St Louis MO
    Quote Originally Posted by FastKatt View Post
    HTH
    You WB tune? A 3.2 on a GEN V, with no cam, rockers or IC is impressive, if you have no knock and are running a decent AFR. Times look very good too.
    04 Indy SS build #972 - Traded
    2010 Camaro SS LS3
  3. #3 Re: What would i have to do to safely run a 3.0 inch pulley?
    St. Louis Mo.
    HTH
    If that stands............can you say "factory freak?"
    I would say get Trannyman to get your stuff tuned up. And good luck with the 12's.
    I would guess if you had a different DP at least it would free up some more HP for ya. Also are you running the stock airbox on your car? You might wanna consider that to allow a bit more air and cooler air into the system.
    Just a thought
    James Shafer
    St. Louis MO
  4. #4 Re: What would i have to do to safely run a 3.0 inch pulley?
    SE Level Member GTP SE's Avatar
    Ankeny, IA
    13.4 for myself with mods in sig and the 3.2. Gen 3 though
    2001 GTP Special Edition
    |ZZP PCM|Headers|Ported LIM and blower|3.2 / 3.4 pulley|1.9's|MSD wires|Drilled 180* T stat|3" ZZP Catback l
  5. #5 Re: What would i have to do to safely run a 3.0 inch pulley?
    TDCRacing
    Guest
    got any kr?
  6. #6 Re: What would i have to do to safely run a 3.0 inch pulley?
    Ankeny, IA
    Who me?
  7. #7 Re: What would i have to do to safely run a 3.0 inch pulley?
    TDCRacing
    Guest
    yeah you
  8. #8 Re: What would i have to do to safely run a 3.0 inch pulley?
    Feb 2008
    Rkrd, IL
    Quote Originally Posted by IndeedSS View Post
    No, I want to get a WB soon
    I am going to get a Dyno Pull 4/12/08, I will be posting the sheet & video
    Quote Originally Posted by GeddyLee View Post
    If that stands............ can you say "factory freak?"
    Just a thought
    You saying I'm lying???
    What would Trannyman "tune up"? I have a PowrTuner...
    Did you click my mods list in my sig? I have PaceSetters, they come with a DP...
    I'm running a DIYS FWI
    Quote Originally Posted by TDCRacing View Post
    got any kr?
    With the 3.4, maybe a blip or 2 of 1-2deg
    With the 3.2, I had 2-3deg at the top of the gears then...
    Now 3.4 I see maybe 4 lines in 20,000 with under 1deg
  9. #9 Re: What would i have to do to safely run a 3.0 inch pulley?
    St. Louis Mo.
    Nope wasn't saying that. I thought I had read that you had only a few options hence me saying what I said. I might have seen someone else's profile or listing of their mods.
    I never clicked on your profile to see what you ACTUALLY HAD, my error again.
    Sorry
    James Shafer
    St. Louis MO
  1. Installing 6 1/2 Inch Front Speakers [*]
    By webracin in forum How To Write-Ups/Tech Tips
    Last Post: 04-28-2012, 11:45 PM
  2. What pulley and plugs to get??
    By TDCRacing in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-21-2008, 12:04 PM
  3. Pulley Puller
    By SyntheticShield in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-11-2008, 02:52 PM
