Quote Originally Posted by 1bad3800 View Post
i had the same noise in my car and it came and went then the motor just went it is way 2 fast 2 be a lifter and even if so.. noises travle travle throught the motor do you have a after marked boost gauge and dose the car miss fire at all..? that would let you know if it is in the valve train .. that is a hard noise that dunt sound soft trust me i ave done many 3800 motors i am doing one now in my car now because of the same type noise ...
A couple things if I will...
1) Care to tell me how a boost gauge will aid in telling if there is a valvetrain issue?
2) A Boost gauge won't tell if there is a misfire...only thing is will tell you is if you have a vacuum leak or not...
3) If you let a noise like that come and go and not even attempt to fix it...you shouldn't be around cars.
4) Try using F7. It is a WONDERFUL thing. My head hurts after reading that.
