Thread: help with the knock please
Results 1 to 13 of 13
  1. #1 Re: help with the knock please
    SE Level Member 1bad3800's Avatar
    Jan 2009
    bensalem pa
    i had the same noise in my car and it came and went then the motor just went it is way 2 fast 2 be a lifter and even if so.. noises travle travle throught the motor do you have a after marked boost gauge and dose the car miss fire at all..? that would let you know if it is in the valve train .. that is a hard noise that dunt sound soft trust me i ave done many 3800 motors i am doing one now in my car now because of the same type noise ...
  2. #2 Re: help with the knock please
    Quote Originally Posted by 1bad3800 View Post
    A couple things if I will...
    1) Care to tell me how a boost gauge will aid in telling if there is a valvetrain issue?
    2) A Boost gauge won't tell if there is a misfire...only thing is will tell you is if you have a vacuum leak or not...
    3) If you let a noise like that come and go and not even attempt to fix it...you shouldn't be around cars.
    4) Try using F7. It is a WONDERFUL thing. My head hurts after reading that.
  1. Knock Knock - What is it?
    By Blown97 in forum Brakes/Suspension/Chassis
    Last Post: 11-11-2009, 12:28 AM
  2. Terrible knock..need some help!!!!!
    By FooteGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-01-2009, 11:57 AM
  3. bad knock...
    By FooteGTP in forum Introductions/Noob Questions
    Last Post: 06-29-2009, 04:35 PM
  4. How much knock is ok
    By jacobmh27 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-10-2009, 05:35 AM
  5. Bad EGR = knock?
    By Sabrewings in forum General Tech Discussion
    Last Post: 07-31-2008, 07:13 PM
