Thread: help with the knock please
Results 1 to 13 of 13
  1. #1 Re: help with the knock please
    Nothing is too fast if it is bottom end related IMO...pull and check the plugs...if they are damaged then it is in the bottom end...if not...sounds like a bad lifter. Cheapest experiment I would try would be to buy some Lucas Oil Stabilizer and throw some in there and if it stops...THEN its valvetrain related.
  2. #2 Re: help with the knock please
    GTX Level Member JoelW98GTP's Avatar
    Nov 2009
    Portsmouth, OH
    Just curious, what could it be in the bottom end to tick that fast and consistent at an idle? Anything I've ever heard from the bottom end is knocking or clanking at a slower pace more on the rpm range of the crank from a bad rod or main bearing or wrist pin versus the faster valve train cycles.
    98 GTP - Autolite 104s, wires, 180* t-stat, fwi, catless dp and plog, glasspack res, Reptile tuned PCM, tinted tails.
    91 Toyota MR2 Turbo - 327RWHP 322RWTQ 11.48@122mph
    03 BMW 325i - tint. stock.
  3. #3 Re: help with the knock please
    Quote Originally Posted by JoelW98GTP View Post
    You've never heard some of the things that have happened to my car then have you?
    LMAO!
    I had a rod bearing spin around...and it clattered VERY fast...strange...but it did...oh...and cam bearings that come out too sound pretty nice
  1. Knock Knock - What is it?
    By Blown97 in forum Brakes/Suspension/Chassis
    Last Post: 11-11-2009, 12:28 AM
  2. Terrible knock..need some help!!!!!
    By FooteGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-01-2009, 11:57 AM
  3. bad knock...
    By FooteGTP in forum Introductions/Noob Questions
    Last Post: 06-29-2009, 04:35 PM
  4. How much knock is ok
    By jacobmh27 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-10-2009, 05:35 AM
  5. Bad EGR = knock?
    By Sabrewings in forum General Tech Discussion
    Last Post: 07-31-2008, 07:13 PM
