Thread: oil is overfull and smells like gas???
Results 1 to 20 of 34
  1. #1 oil is overfull and smells like gas???
    GT Level Member shawn3091's Avatar
    Jan 2009
    State College PA
    so i was installing all my new parts on my 97 gtp from zzperformance today and i checked the oil and its about a inch over full mark, looks normal but sorta smells like gas? so what could the problem be?, theres probably about 500 miles on it since i just put amsoil in.
  2. #2 Re: oil is overfull and smells like gas???
    GTX Level Member 97gtsc's Avatar
    Jul 2008
    Livonia MI.
    Injectors going bad?
  3. #3 Re: oil is overfull and smells like gas???
    Jan 2009
    State College PA
    dont know, ran great when i drove it last, and starts right up with no problem
  4. #4 Re: oil is overfull and smells like gas???
    GT Level Member mikedinthecity's Avatar
    Apr 2009
    Southfield, Michigan
    there is def fuel getting in, it is happening when you shut it off....it sits and gas goes down below in the oil. somewhere the fuel is not turning off...probobly just 1
    2000 Daytona 500 GTP. fender well intake K&N, 180 tstat, flipped dog bones, strut2strut brace, sd headers coated n wrapped, 3in dp, 3.25 pulley, pcm tune, led tails, angel eye halos w 100 watt h1s, p&p heads, p&p m90, yella terra alum roller rockers, head studs, 8mm wires, al104s, 2007 l26, 329s hd diff, alum sub frame
  5. #5 Re: oil is overfull and smells like gas???
    Portland Oregon
    Pop the fuel rail off and turn the key to on. Watch for the leaker and replace.
  6. #6 Re: oil is overfull and smells like gas???
    Jan 2009
    State College PA
    ok, i will try that when my pcm comes back and i get everything else all done
  7. #7 Re: oil is overfull and smells like gas???
    i pay to play badbrad's Avatar
    Dec 2008
    hueytown, alabama
    what did u do to it , or install thats possibly related to fuel. they possibly right inj sticking or leaking letting raw fuel back into oil. damn, u put in amsoil too. i don't know what to tell u. i'd drain it then refill but thats gonna suck. u don't need fuel thinning ur oil and washing your rings and bearings...good luck man.
  8. #8 Re: oil is overfull and smells like gas???
    Jan 2009
    State College PA
    didnt install anything fuel related only put no more than 500 miles on it since i bought the car wrecked and fixed/painted the whole thing, ran great, its in garage for winter now and i got some things from zz to put on it and i pulled the dipstick and it smelled like gas and was overfull. would the fuel pump still prime without the pcm being plugged in so i could check them for leaks now?
  9. #9 Re: oil is overfull and smells like gas???
    Charles City, IA
    Probally have a plug not firing to well and not burning all the fuel.
    SMGPFC Two Nipple General
  10. #10 Re: oil is overfull and smells like gas???
    Donating Users kfish's Avatar
    Ohio
    Quote Originally Posted by shawn3091 View Post
    no the fuel pump will not prime without the pcm plugged in.
  11. #11 Re: oil is overfull and smells like gas???
    ^^Exactly. I'd change the plugs and dump in some Lucas Injector cleaner...and some higher octane gas...like higher than 92+. Then I'd take off the fuel rail and blow it out with an air gun if you can and see if anything comes out of it...eg. buildup...then replace your injector O-Rings...they are like $5 or less. Also...since the fuel rail is aluminum...check to see if it is bent...as that happens VERY easily and there might not be an injector seating just right. That...could then lead to a fuel AND vacuum leak...like I had...the bracket that bolted the fuel rail to the LIM was bent a little...once bent back...fixed everything right up.
  12. #12 Re: oil is overfull and smells like gas???
    Jan 2009
    State College PA
    i have all new ac plugs in it along with new wires that i put on and i will check out the fuel rail, it doesnt look bent, how could i tell? and i will wait until i get the pcm in it and cycle the key with the rail off and see if any of the injectors leak
  13. #13 Re: oil is overfull and smells like gas???
    Jan 2009
    State College PA
    i noticed the vacuum line going to the fpr was cracked open, so it may have been part of the problem, i will still be checking the injectors, pcm will be here monday
  14. #14 Re: oil is overfull and smells like gas???
    GTX Level Member JoelW98GTP's Avatar
    Nov 2009
    Portsmouth, OH
    While you're waiting on your pcm, I'd go ahead and change the oil and filter for sure before starting it even one more time even just to trouble shoot.
    98 GTP - Autolite 104s, wires, 180* t-stat, fwi, catless dp and plog, glasspack res, Reptile tuned PCM, tinted tails.
    91 Toyota MR2 Turbo - 327RWHP 322RWTQ 11.48@122mph
    03 BMW 325i - tint. stock.
  15. #15 Re: oil is overfull and smells like gas???
    Charles City, IA
    If there was no vacuum at the fuel pressure reg it would make you run rich as hell.
  16. #16 Re: oil is overfull and smells like gas???
    Jan 2009
    State College PA
    thats what i figured, way way to much fuel at idle. and @Joel I am going to drain it and put cheap stuff in for a while and make sure all is good and then i will go back to amsoil, says i should change 2-500 miles for the new rockers i put on it anyway.
  17. #17 Re: oil is overfull and smells like gas???
    Charles City, IA
    Shameless plug I sell amsoil.
  18. #18 Re: oil is overfull and smells like gas???
    Jan 2009
    State College PA
    shameless plug? i like amsoil and my dad is a dealer. previous owner ran amsoil in this car since it was new also
  19. #19 Re: oil is overfull and smells like gas???
    Charles City, IA
    Pluging my self in saying I sell amsoil. Did not no where you get it. I sell it about as cheap as I can with out losing money. Probably cant beat your dads prices. lol
  20. #20 Re: oil is overfull and smells like gas???
    Jan 2009
    State College PA
    oh ok lol, i get it for what it costs him
  1. funny smells driving me nuts
    By X97prixX in forum General Tech Discussion
    Last Post: 10-20-2009, 11:56 AM
  2. Smells like FIre
    By chitownballer8908 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-13-2009, 07:06 PM
  3. Car smells like cig smoke and dogs
    By shawnz90 in forum Detailing Tips and Tricks
    Last Post: 08-30-2009, 09:21 AM
  4. Help!! 2004 Comp G Smells
    By dnnschuett in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-11-2008, 09:16 PM
