Thread: oil is overfull and smells like gas???
Results 1 to 20 of 34
  1. #1 Re: oil is overfull and smells like gas???
    ^^Exactly. I'd change the plugs and dump in some Lucas Injector cleaner...and some higher octane gas...like higher than 92+. Then I'd take off the fuel rail and blow it out with an air gun if you can and see if anything comes out of it...eg. buildup...then replace your injector O-Rings...they are like $5 or less. Also...since the fuel rail is aluminum...check to see if it is bent...as that happens VERY easily and there might not be an injector seating just right. That...could then lead to a fuel AND vacuum leak...like I had...the bracket that bolted the fuel rail to the LIM was bent a little...once bent back...fixed everything right up.
  2. #2 Re: oil is overfull and smells like gas???
    GT Level Member shawn3091's Avatar
    Jan 2009
    State College PA
    i have all new ac plugs in it along with new wires that i put on and i will check out the fuel rail, it doesnt look bent, how could i tell? and i will wait until i get the pcm in it and cycle the key with the rail off and see if any of the injectors leak
  3. #3 Re: oil is overfull and smells like gas???
    Jan 2009
    State College PA
    i noticed the vacuum line going to the fpr was cracked open, so it may have been part of the problem, i will still be checking the injectors, pcm will be here monday
  4. #4 Re: oil is overfull and smells like gas???
    GTX Level Member JoelW98GTP's Avatar
    Nov 2009
    Portsmouth, OH
    While you're waiting on your pcm, I'd go ahead and change the oil and filter for sure before starting it even one more time even just to trouble shoot.
    98 GTP - Autolite 104s, wires, 180* t-stat, fwi, catless dp and plog, glasspack res, Reptile tuned PCM, tinted tails.
    91 Toyota MR2 Turbo - 327RWHP 322RWTQ 11.48@122mph
    03 BMW 325i - tint. stock.
  1. funny smells driving me nuts
    By X97prixX in forum General Tech Discussion
    Last Post: 10-20-2009, 11:56 AM
  2. Smells like FIre
    By chitownballer8908 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-13-2009, 07:06 PM
  3. Car smells like cig smoke and dogs
    By shawnz90 in forum Detailing Tips and Tricks
    Last Post: 08-30-2009, 09:21 AM
  4. Help!! 2004 Comp G Smells
    By dnnschuett in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-11-2008, 09:16 PM
