If there was no vacuum at the fuel pressure reg it would make you run rich as hell.
thats what i figured, way way to much fuel at idle. and @Joel I am going to drain it and put cheap stuff in for a while and make sure all is good and then i will go back to amsoil, says i should change 2-500 miles for the new rockers i put on it anyway.
