Thread: stock V8 mufflers on a gtp
Page 3 of 5 FirstFirst 12345 LastLast
Results 41 to 60 of 86
  1. #41 Re: stock V8 mufflers on a gtp
    Jersey
    Quote Originally Posted by rocafella2032 View Post
    i understand. i assume the way the dic is which would be callobrated in some way, its still going to find the avarage the same way. i dont find it hard to beileve that how well the mufflers flow compared to stock that i would get better mileage. Im not trying to argue, i just think regardless of how it calculates it improved.
    The DIC is a joke, its their to look pretty and that's it. If you want an accurate reading your going to have to do it the old fashion way, with simple math and i very very highly doubt you gained mpg by mufflers.
    Hell my DIC shows mpg dropping 1 by 1 when at idle...
    16' wrx sti- stock
  2. #42 Re: stock V8 mufflers on a gtp
    Apr 2009
    Maine
    I've calculated my mileage the normal way at almost every fill up. The DIC is consistently ~2 MPG above the actual. It usually reads 24-25.
  3. #43 Re: stock V8 mufflers on a gtp
    michigan
    So just put a dump on it then. The resonator's or glasspacks do nothing to harm exhaust flow. Don't know where you get your information from but all they do is quiet down the exhaust. Like I said if your worried about obstructions in the exhaust system that really doesn't hurt it...then just dump it. I'm sure that your not even making near 350 FWHP...so the stock resonator/catback/mufflers/Y-Pipe...etc...has been dyno proven to not have any flow issues.
    anything that causes turbulence in the exhaust flow will slow it down. even a gutted cat or glasspack will harm flow. this isn't rocket science Jr. here is a cutaway of a glasspack, every one of those little scoops is going to slow down exhaust flow. i'm not saying our going to lose 25hp from a glasspack, but is will harm performance.
    i understand that the OEM exhaust is "good enough" for 350hp, but a better flowing one will BETTER performance than the stock one. if you honestly think that a more restrictive exhaust is not going to harm performance, your a moron.
  4. #44 Re: stock V8 mufflers on a gtp
    the catback will not net you any gains even if youre making a million horsepower. only change it if you want a different tone out of it. otherwise just leave it alone and run with it. these cars just dont make power from changing up the catback. its literally unheard of. yeah, you might pick up 5-7 whp if you drop the catback at the track if you have a full blown cammed and intercooled setup, but why make the car unnecessarily louder and uglier sounding for 2 whp when youre not really modded or 10 if youre heavily modded? it just doesnt make sense to waste money on it.
  5. #45 Re: stock V8 mufflers on a gtp
    Quote Originally Posted by chunky View Post
    BUT...your missing the entire point...if your not making that kind of power it isn't going to help you...and anyone that thinks it does...is a moron.
  6. #46 Re: stock V8 mufflers on a gtp
    Portland Oregon
    WRONG.... I had my n/a setup running 14.7-14.8's with a gmpp dual cat-back. I swapped on a stock catback from a gtp and I lost 2mph in the traps and dropped to consistent 14.9-15.1's. There ya go, it's now proven with time slips as evidence ;-)
  7. #47 Re: stock V8 mufflers on a gtp
    in a house
    Quote Originally Posted by OH4CompG View Post
    Haha, I don't think so. Many variables here, temp, driver, track condition and I could go on. Quit being foolish
  8. #48 Re: stock V8 mufflers on a gtp
    Jersey
    Was it the same day? same hour? same weather? same time of year? same track prep? same amount of tread on tires? same gas? same amount of gas? did you weigh the exact same amount? get my point?
    16' wrx sti- stock
  9. #49 Re: stock V8 mufflers on a gtp
    Portland Oregon
    Actually yes, it was the same event and runs were within a few hours of each other. A local club member had a stock GTP and I was curious. I didn't just make one run to confirm this, there were a few runs done to be sure. Just because you haven't actually done it to test it out doesn't mean you can be so quick to judge. I never said that the stock cat-back isn't "good" to that much FWHP, but you're absolutely wrong if you think that you will get NO improvement from a cat-back.
  10. #50 Re: stock V8 mufflers on a gtp
    in a house
    Soo, you switched cat backs right there at the track? I find that hard to believe.
  11. #51 Re: stock V8 mufflers on a gtp
    Portland Oregon
    Do you ever actually get under your car? lol Two bolts and slide the system off of 7 hangers. Jack the passenger side of the car and you can slide the whole thing out the back. I had a welded GMPP exhaust and the stocker is also welded. Comes out in one piece. Had it in and out in 15 minutes taking my time.
    Edit: I realize some of you live in states that salt the roads and this is unreasonable for you as corrosion rusts everything under your car. I live in Oregon, no salt here.
  12. #52 Re: stock V8 mufflers on a gtp
    You probably had a .1 or .2 worse 60 foot. Show me slips...or I call BS.
  13. #53 Re: stock V8 mufflers on a gtp
    i call BS as well. there is no way in hell an n/a GP would gain or lose any power from switching the catback. youre full of it.
  14. #54 Re: stock V8 mufflers on a gtp
    Donating Users blowfishRus6's Avatar
    g.a.
    back pressure is a good thing sometimes.....
    white 04 comg G gtp. wizair, pacesetters, slp 1.8 rr
    its slow.
  15. #55 Re: stock V8 mufflers on a gtp
    Portland Oregon
    So you've done this then and put your own car on a dyno to prove it? Don't run your mouth, or you're calling yourself out as a bull**** artist. Go flex your E-muscle in someone elses direction.
    Specs on the car were as follows.....
    2002 Chevy Impala
    GT1 cam
    Comp 105's
    Ported heads (intake and exhaust polished and blended to gasket match)
    .051 MLS head gaskets to raise compression
    HV3 intake insert
    ZZP 1.0 PCM with tables adjusted for the GT1
    Home made FWI
    PLOG
    2.5" cat-less DP and GMPP exhaust
    I may have missed a thing or two. It's been more than a year since I've had the car. Power pole on the side of a road took it away from me.
    Results may have been a little more drastic for me because the exhaust would have exhibited my only back pressure due to the PLOG and cat-less DP. I'll have to look for the slips but I promise you got no BS here. The only reason for that experiment was to see if I could get the same performance on the car out of a quieter exhaust. And I couldn't, so I went back to the GMPP.
  16. #56 Re: stock V8 mufflers on a gtp
    Portland Oregon
    Quote Originally Posted by blowfishRus6 View Post
    Yes it was. I bolted in a catted DP once and it felt like I had more low end torque. Don't have any proof of this one though, just the butt dyno.
  17. #57 Re: stock V8 mufflers on a gtp
    I'd just like to point out how FAIL it is port match your heads to the exhaust gaskets
    LMAO!!
  18. #58 Re: stock V8 mufflers on a gtp
    in a house
    lol
  19. #59 Re: stock V8 mufflers on a gtp
    im not saying you didnt get a restriction by adding the stock catback in the mix, but im saying that there is no way in hell you lost enough power to lose two tenths of a second unless you were to botch the launch or try and drive the transmission by yourself.
    ill call BS until the cows come home on this one. you were making what, 200 whp if that? a stock catback might drop that to 195 whp under extreme circumstances. 5 whp will not get you two tenths of a second.
  20. #60 Re: stock V8 mufflers on a gtp
    Portland Oregon
    LMAO!!
    Look, you as well as any dumbass out there knows that you keep the D-shape of the exhaust port but you enlarge the port opening and polish the runners to match the port of your exhaust and intake manifold. Why don't you go take a look at some ported heads someday genius. You wanna talk about fail, let's talk about how much your people skills and respect for others fail here. I respect your opinions and your experience but if you don't let others bring their knowledge and experience to the table then you have no business being on a community forum. Just because people don't do things your way doesn't mean that it's the wrong way. You wanna tell me who's N/A GP or Impala for that matter you've seen go faster than 14.7 at 94mph with no power adders save for a cam? Thought not lol. Go be petty someplace else
  1. question about stock mufflers
    By bhrfpa11 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-03-2009, 08:10 AM
  2. Mufflers or stay w/ stock
    By mscally07 in forum General Tech Discussion
    Last Post: 11-06-2008, 04:21 AM
  3. GXP mufflers?
    By Iron Indian in forum Off Topic Discussion
    Last Post: 02-14-2008, 05:22 PM
