Thread: Replaced LIM Car Wont Start
Page 2 of 2 FirstFirst 12
Results 21 to 25 of 25
  1. #21 Re: Replaced LIM Car Wont Start
    Ontario
    Well I kinda didnt change the oil!!!!! Had no coolant in it originally so figured it would be fine to run for a bit....My bad........BillBOOST would the crack be noticable because i took it off and cleaned the crap out of it and didnt see anything
  2. #22 Re: Replaced LIM Car Wont Start
    SE Level Member reveregtp's Avatar
    Nov 2008
    Revere, MA
    i wish i saw this earlier...
    i was going to say the coolant in the intake is from the tb not being sealed correctly. Now, with coolant coming in from there, grab some maf + tb cleaner and spray that bish down
    best advice: complete tear down and take your time
  3. #23 Re: Replaced LIM Car Wont Start
    Ontario
    Tear down for what....To clean everything out because the gaskets are brand new????
  4. #24 Re: Replaced LIM Car Wont Start
    GT Level Member t24moore's Avatar
    Feb 2008
    Houston
    Doesn't matter if the gaskets are brand new, you obviously didn't do something right. Which is apparent by you doing a LIM job and not changing the oil. If it makes you feel any better I ****ed up doing my head gaskets the first time I attempted it. Car started fine but had coolant pouring everywhere. I had to tear it back down again. Change the oil and see if it sludge up again.
    Comp Turbo 6765 T4-ST5-A2A IC-Ported Heads-Custom Turbo headers-80 lb inj-F-Body UIM and LIM-AEM WB, TEP trans w 1" chain and Circle D TC, Dual 255s, Bilstien Struts
    WHY IS EVERYONE SO OPPOSED TO DOING A COMPRESSION TEST TO TROUBLESHOOT PROBLEMS?
  5. #25 Re: Replaced LIM Car Wont Start
    Ontario
    Well I figured out why coolant was coming out of the TB....The TB wasnt tightened and the coolant lines going through the TB were not sealed therefor sending coolant through the TB when i throttled....I tightened and cleaned the TB and Intake cleaned Maf etc, changed the oil blew out the spark plug holes but cant get it started now.... There wasnt alot of coolant in the oil but I figured it was from not changing the oil
  1. Wont start
    By EmEaston24 in forum General Tech Discussion
    Last Post: 08-27-2009, 09:20 AM
  2. car wont start right away .
    By NEONNIGHT34609 in forum General Tech Discussion
    Last Post: 02-15-2009, 01:40 PM
  3. car wont start
    By 98gpgtp in forum General Tech Discussion
    Last Post: 10-22-2008, 05:26 PM
  4. Car wont start
    By 94GTRoyalty in forum 3.4L V6 (LQ1) DOHC
    Last Post: 10-13-2008, 01:57 PM
  5. Car wont start need help!!!!
    By drums4life0922 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-02-2008, 09:34 AM
