sounds good. so long as you know what youre doing. just trying to keep up with ya.
good work on the crow cams springs. the walbro should work out fine if its setup right. not sure if those have problems with when you run the talk lower or not. trust yourself with the timing chain, only you can say its right or not.
however, i would suggest picking up another couple pullies.
