Thread: L67 heads
Results 1 to 9 of 9
  1. #1 L67 heads
    Apr 2009
    bethel
    Is there any way i can put l67 heads into my l36? Im doing a topswap but i dont have all the parts for it yet but want to get somewhere on te project.
  2. #2 Re: L67 heads
    GTP Level Member Scimmia's Avatar
    QCA, IA
    yeah, it's required for a top swap. Have you read the top swap thread in the NA forum?
    2001 Buick Regal LS - Almost Stock
  3. #3 Re: L67 heads
    Barksdale AFB, LA
    Why would you want to put the heads on if you don't have all the parts yet? There's nothing to gain just by switching to L67 heads. You'd also have to find a way to plug the injector bosses.
    2009 Subaru Impreza WRX STI
  4. #4 Re: L67 heads
    Banned - Busted For Scamming
    Feb 2009
    you can keep the l36 heads, but it would require custom rails and injector bosses in the l67 lower intake manifold, the same setup that im doin for my brothers 3.8 camaro, we are m90ing it
  5. #5 Re: L67 heads
    Apr 2009
    bethel
    I know the l67 heads are required and i also know that there will be no power gain. I dont have all the parts for the topswap yet but will have the heads soon My question was can i just put the heads in for now and do the rest later. or will i need to do some modifications to the fuel rail?
  6. #6 Re: L67 heads
    Feb 2009
    you will have holes in the l67 heads that you will have to plug. buy the heads, get all the parts, then put on all at once.
  7. #7 Re: L67 heads
    Feb 2008
    San Diego, CA
    If you do want to put the L67 heads on early, you could plug the injector holes in the heads with a set of junk injectors.
    But I agree you might as well do it all at once. I don't see splitting up the job saving you any time or effort, as you'll have to remove everything down to the heads anyway.
  8. #8 Re: L67 heads
    Barksdale AFB, LA
    It's a waste of gaskets to tear it down now just to put heads on, then tear it down later to do the rest.
  9. #9 Re: L67 heads
    Apr 2009
    bethel
    good point.. thanks for the advise
  1. Heads
    By 04BlackComp_G in forum General Tech Discussion
    Last Post: 03-31-2009, 10:59 PM
  2. L36 Heads
    By Abrasive in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-13-2008, 09:02 AM
  3. heads for a gt
    By Grandprixboy1224 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-06-2008, 11:21 PM
