Thread: ZZP XPZ Build
Results 1 to 20 of 255
  1. #1 Re: Cam, Heads, Etc. Install
    first off: sell those OE-Rs and then just buy some ls7 lifters for way cheaper and they wont be loud like the OE-Rs will be.
    second: do you have a bigger pulley than a 3.0 to use while youre figuring out your basic tune? youre going to need one.
    third: have you read about the 105s having a problem with breaking?
    dont get rockers, the stock ones work fine. you shouldnt need new bearings so long as your car runs well and you always took care of the oil. if you havent bought head studs do it now, youll need them for when you have to take your motor apart when you break something. they also last forever, unlike the stock TTY head bolts. do you know that the rollmasters need a little bit of work on them and/or the oil pump cover so they dont break from rubbing on anything or running on an angle? do you have a GIANT breaker bar or a *****in impact for the crank bolt? youll need that too.
    just a few thoughts there, might have missed something.
  2. #2 Re: Cam, Heads, Etc. Install
    Donating Users bbptech's Avatar
    Box Elder, South Dakota
    where could i go to get head studs? and for the double roller, i forgot to mention that i have a new machined oil pump cover so is doesnt rub. No i didnt know about the 105's having problems breaking. Where could i pick up some new Ls7 lifters? They actually fit? How are the OE-R's so loud? And as for the pulley, i do havea larger one. its a 3.4. that should be good enough right? And the crank bolt will be easy. We've had to take the balancer and everything off before to replace the crankshaft positioning sensor.
    ZZP 10.4mm's, ZZP S2 IC, 3.4, 3.0, Ported Gen V, ZZP Headers, ZZP CNC Heads, ZZP 78mm TB, ZZP Aluminum Valve Covers, Meziere Electric WP, ZZP Fuel Pump, ZZP Fuel Logs, 65 Mototrons, 3.29's, 2500 Stall. Tuned by GLANZERGTX and Kyle. E85 Converted, 21* Timing
  1. Intense's S3 Heads VS. ZZP's S3 Heads.
    By pontiackid in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-15-2009, 02:08 PM
  2. Any other Ska heads out there?
    By Thunderturd in forum Off Topic Discussion
    Last Post: 08-20-2009, 03:18 PM
  3. L67 heads
    By DLAVENGER in forum General Tech Discussion
    Last Post: 06-24-2009, 07:03 AM
  4. L36 Heads
    By Abrasive in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-13-2008, 09:02 AM
