Thread: ZZP XPZ Build
Results 21 to 40 of 255
Threaded View
  1. #1 ZZP XPZ Build
    Donating Users bbptech's Avatar
    Box Elder, South Dakota
    Im gonna be doing an install before i head to ZZP so i dont have to pay an outrageous 1000 dollars for labor install. I have an XP cam, ZZP CNC Ported Heads with 105 springs, ZZP 7.05 pushrods, OE-R 875 lifters, Pacesetters, 42.5 injectors, 3.0 S/C pulley, 85mm MAF, fuel pump re-wire and Rollmaster Double Roller Timing Chain all on its way and am just wondering some things before i tear into it.
    Should i get rockers?
    What kind of rockers should i get?
    Do i need to put new cam bearings in?
    What problems will i run into?
    All help would be greatly appreciated. Thanks.
    ******Updated******
    Decided to scrap the whole deal with ZZP and went with the INTENSE. I am now doing the Intense Stage 4 Heads and Cam pckage. Cometic .52/ 3.84" bore Head Gaskets, INTENSE 7.05" Oil Restricted Pushrods, JP Double Roller, 42.5 lb. Injectors Meziere Electric Water Pump, 3.0 pulley, OE-R 875, Pacesetters.
    ZZP 10.4mm's, ZZP S2 IC, 3.4, 3.0, Ported Gen V, ZZP Headers, ZZP CNC Heads, ZZP 78mm TB, ZZP Aluminum Valve Covers, Meziere Electric WP, ZZP Fuel Pump, ZZP Fuel Logs, 65 Mototrons, 3.29's, 2500 Stall. Tuned by GLANZERGTX and Kyle. E85 Converted, 21* Timing
  1. Intense's S3 Heads VS. ZZP's S3 Heads.
    By pontiackid in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-15-2009, 02:08 PM
  2. Any other Ska heads out there?
    By Thunderturd in forum Off Topic Discussion
    Last Post: 08-20-2009, 03:18 PM
  3. L67 heads
    By DLAVENGER in forum General Tech Discussion
    Last Post: 06-24-2009, 07:03 AM
  4. L36 Heads
    By Abrasive in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-13-2008, 09:02 AM
