Thread: ZZP XPZ Build
Page 11 of 13 FirstFirst ... 910111213 LastLast
Results 201 to 220 of 255
  1. #201 Re: ZZP XPZ Build
    Donating Users bbptech's Avatar
    Box Elder, South Dakota
    well ZZP said use the 7.05's for exhaust side and 7.10 for intake side. And if they were too short or too long send em back and they will give longer or shorter ones which ever the case may be. Well i spent like 3 weeks trying to figure if they were too short or too long. By the way using comp cam oe-r's as well for lifters.
    I soaked the lifters in oil for 2 days then started. Was worried if i was gonna be within pre-load specs per comp cams instructions. Didnt wanna start the car after everything and get the lifters pumped up and them ending up being short or long. So i got worried and just threw the stockers back in but that didnt solve the problem.
    So i talked with my dad and showed him everything and what all had to be done. He said he would help me after thanksgiving so i waited for a couple more weeks. We finally got it all figure out and everything is fine and in spec finally.
    ZZP 10.4mm's, ZZP S2 IC, 3.4, 3.0, Ported Gen V, ZZP Headers, ZZP CNC Heads, ZZP 78mm TB, ZZP Aluminum Valve Covers, Meziere Electric WP, ZZP Fuel Pump, ZZP Fuel Logs, 65 Mototrons, 3.29's, 2500 Stall. Tuned by GLANZERGTX and Kyle. E85 Converted, 21* Timing
  2. #202 Re: ZZP XPZ Build
    Alright here's the new pics. Got tired of the red and just starrin at it so i repainted it black haha.
    My red dash pieces i painted.
    My triple pillar pod with triple areoforce scan gauges
    Engine painted black. Valve covers arent the ones ill be using, just put them on there to cover the heads.
  3. #203 Re: ZZP XPZ Build
    Donating Users blowfishRus6's Avatar
    g.a.
    yea that red would drive me crazy.
    triple aeroforce's??? dang man
    lookin good.
    white 04 comg G gtp. wizair, pacesetters, slp 1.8 rr
    its slow.
  4. #204 Re: ZZP XPZ Build
    haha hell ya i cant wait to get them lit up. And thank u much man. Tranny is almost done as we speak
  5. #205 Re: ZZP XPZ Build
    Ok so here's whats up now. Im sending my S3 IC back because the front bank doesnt retain PCV function. And they dont know when more will be available. So ima send it back for a S2 gen V. I really want the S3 but if they dont know when more will be available then i dont wanna wait since my whole build is almost completely done.
    The tranny situation: Here's all the things that need to be replaced besides all the stuff i left them with.
    1-2 Band
    Reverse Band Torque Signal Valve
    TCC Combination Valve
    TCC Regulator Valve ACT Feed Valve
    ETC Solenoid
    Thrust Washer Kit
    4 Imput Steels (or seals, didnt understand quite what he said)
    Pump Vain Kit
    2 Bushings
    Lower Sprag
    MLPS
    Input Speed Sensor
    Sun Gear
    3,2,1 Clutch Pistons
    Tranny had 193,000 miles on it. All valve bodies were leaking.
  6. #206 Re: ZZP XPZ Build
    you dont need a stage 3 intercooler. a stage 2 is better anyway.
  7. #207 Re: ZZP XPZ Build
    why do u say that Bio? Wouldnt the Stage 3 be better because of heat soak
  8. #208 Re: ZZP XPZ Build
    do you like trying to do 150 mph on the highway? do you like hot lapping at the track? if not then you dont need a stage 3 because heat soak wont happen.
  9. #209 Re: ZZP XPZ Build
    hell yes 150 on the highway everyday Bio. Naw just kidding but ya i understand
  10. #210 Re: ZZP XPZ Build
    Heres a little update for u guys.
    Got my tranny back yesterday. Its all done and completely built finally. Clean and everything. Has all the goodies i bought then all new parts from them that were wore out after 193,000K miles on it. Will have quite a few pics of it along with all the worn out parts.
    My Gen V was sent out to Josh Vandenberg for polishing yesterday. Cant wait to get that back.
    My S3 that didnt have PCV for the front bank was sent back 2 days ago back to ZZP for the S2 since they didnt have an idea on when they will have the next batch of properly drilled PCV channels plates for the S3's.
    Pics will be later tonight.
  11. #211 Re: ZZP XPZ Build
    g.a.
    gettin closer and closer!!
    its slow.
  12. #212 Re: ZZP XPZ Build
    bank account getting lower and lower
  13. #213 Re: ZZP XPZ Build
    g.a.
    haha
    its slow.
  14. #214 Re: ZZP XPZ Build
    im with this guy. i dont want to get back into these cars for the fact that i know how much money you can spend on it for how much gain youll get from that money.
  15. #215 Re: ZZP XPZ Build
    yes bank account is practically drained. Still gotta come to Missouri to get it tuned yet. lol
  16. #216 Re: ZZP XPZ Build
    GT Level Member pontiackid's Avatar
    KCMO
    Quote Originally Posted by bbptech View Post
    So you ended up going with the 7.10 and a 7.5 lengths instead of the stock lenghts?
  17. #217 Re: ZZP XPZ Build
    yessir
  18. #218 Re: ZZP XPZ Build
    motor is finally in. waitin on my supercharger to get done being polished by josh. Have a problem with the ZZP Headers though. I dont know if any body else has had this problem but the tranny dip stick i had to bend to get in. Its touching the crossover on the back header. is this ok?
    Pics will be up soon.
  19. #219 Re: ZZP XPZ Build
    bend it more so it doesnt touch. or if youre creative get one of those bendy dipstick tubes and then you can run it pretty much wherever you want.
  20. #220 Re: ZZP XPZ Build
    Could that be picked up at any auto parts store. might have to try that. This build is on its final stages.
  1. Intense's S3 Heads VS. ZZP's S3 Heads.
    By pontiackid in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-15-2009, 02:08 PM
  2. Any other Ska heads out there?
    By Thunderturd in forum Off Topic Discussion
    Last Post: 08-20-2009, 03:18 PM
  3. L67 heads
    By DLAVENGER in forum General Tech Discussion
    Last Post: 06-24-2009, 07:03 AM
  4. L36 Heads
    By Abrasive in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-13-2008, 09:02 AM
