Thread: Cam Install Kit- What do I really need?
Results 1 to 8 of 8
  1. #1 Cam Install Kit- What do I really need?
    SE Level Member 1998gpgt's Avatar
    McHenry, IL
    Well, im getting ready to do a cam swap and i have a few questions. Mainly on what is neccessary out of the ZZP cam install kit. I have 102,000 miles on my 1998 Grand Prix GT. It been about 2,000 miles since the install of the SS kit, with fresh LIM gaskets and a fresh supercharger gasket. So Do the both the LIM gaskets and supercharger gasket need to be changed every time the top end is torn down? And do i really need to buy new cam and crank bolts
    Timing chain dampener--- going to buy
    Timing Chain------------- going to buy
    12 rocker bolts----------- going to buy
    supercharger gasket------ ?????????????????????
    2 coolant passage O-rings- dont need with my ZZP machined LIM
    intake gasket set---------???????????????????????????
    front cover gasket--------going to buy
    ARP assembly lube--------going to buy
    cam bolt----------------- ??????????????????????????????
    crank bolt----------------?????????????????????????????????????
    Thanks is advance
    1998 Grand Prix GT 337whp/363wtq 12.952 @ 112.02
    2000 Grand Prix GT & 2007 Grand Prix GT
    2004 GTO 13.610 @ 102.69
    1985 Cutlass 455/TH350
  2. #2 Re: Cam Install Kit- What do I really need?
    SS-DD Level Member IndeedSS's Avatar
    St Louis MO
    definitely yes on the suopercharger gasket.
    I assume you got the aluminum LIM gaskets? If so they are probably fine, unless you tear one pealing off the RTV from the corners on the bottom two pieces. I would go new but I'm really anal about stuff.
    Cam and crank bolt? They are cheap and yours are original, I would go new with those.
    04 Indy SS build #972 - Traded
    2010 Camaro SS LS3
  3. #3 Re: Cam Install Kit- What do I really need?
    GT Level Member DuBob's Avatar
    Lititz, PA
    For what a LIM gasket set costs, just get new.
    You MUST replace the cam bolt, it is TTY and a use-once bolt. The crank bolt I also replace but IMO, it isn't as critical as the cam bolt.
    Make sure you torque things down correctly though.
    One of the First: 2008 Liquid Red Pontiac G8 GT (hers)
    -Intake, Tune, Magnaflow Exhaust, 40% tint.
    -Next: Rims, lowered?, headers?
    One of the Last: 2009.5 Stryker Blue Metallic Pontiac G8 GXP M6 (mine)
    -Intake, Magnaflow Exhaust, 25% tint.
    -Next: Headers and tune.
  4. #4 Re: Cam Install Kit- What do I really need?
    GTX Level Member Toofastgs's Avatar
    Tulsa, Ok
    gaskets yes blower gasket almost rips all the time when you take the blower off. LIM i would there cheap and not worth a coolant leak.
    Bolts i reused mine through several cam installs
    00' GTP 350/420 - Retired
    98' GS - Sold
    Current - Lexus ES300
  5. #5 Re: Cam Install Kit- What do I really need?
    Transmission Expert Trannyman95's Avatar
    Fort Wayne, IN
    I have also reused bolts on my own cars and never had any problems after several times of reusing. To be honest though the ZZP kit is the way to go. Its better to be safe than sorry and their kit includes pretty much everything you will need, the top option kit that is. The last ones that I used or customers brought me had GM gaskets exept for the intake gaskets which were still plastic and looked like fel-pro or victor gaskets as only GM sells the metal ones, but that metal ones are the only ones I install now unless you know that the engine will be taken back apart in the next 30-40K miles. You could try reusing the intake gaskets, again I have done this for myself to save a few $$$ since they were only a few months old but its still best to get new ones as the sealing beads will conform to the mating surfaces over time and maybe not seal up as well the next time around.
  6. #6 Re: Cam Install Kit- What do I really need?
    Wichita, KS
    Quote Originally Posted by Trannyman95 View Post
    X2
    My cam, crank, and flex plate bolts on my car have all be reused...countless # of times with no ill effects ever. Eventually, these will be replaced, just due to age, and abuse.
    ~F~
  7. #7 Re: Cam Install Kit- What do I really need?
    McHenry, IL
    Well, then I guess Im buying new LIM and SC gaskets. And I might as well throw in the bolts too, because its only $10 for the pair.
    Thanks for all the help guys
  8. #8 Re: Cam Install Kit- What do I really need?
    SE Level Member WillOverkill's Avatar
    Feb 2008
    Timing chain dampener--- yes
    Timing Chain------------- yes
    12 rocker bolts----------- yes, get GM bolts
    supercharger gasket------ yes
    intake gasket set--------- 110% yes
    front cover gasket--------yes
    ARP assembly lube--------I use STP oil treatment for assembley lube
    cam bolt----------------- have reused these without any failures but recommend for safest install
    crank bolt----------------have reused these without failures
    I also recommend a front cover oil seal for the sake of it.
    I also recommend the black plastic wiring harness retainer that goes behind the crank pulley, very commonly breaks upon removal. When not secured properly due to a broken tab, it will move forward, get sliced apart by the crank pulley and the wiring harness to the cam position sensor will get sliced through as well. Cheap insurance.
    Get Your 3800 Overkilled @ http://www.getoverkilled.ca
  1. Stereo INSTALL.....need help
    By TMOTA503 in forum Audio, Security & Visual Electronics
    Last Post: 02-28-2008, 11:01 PM
  2. 1.9 modded rocker install
    By ExpyGator in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-27-2008, 12:38 PM
  3. DIY catback install?
    By IndeedSS in forum General Tech Discussion
    Last Post: 02-26-2008, 12:04 AM
  4. easiest shift kit to install ?
    By bayareagtp in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-26-2008, 09:18 AM
  5. did I do an install on your gp today?
    By s1795so2 in forum Midwest
    Last Post: 01-06-2008, 06:56 PM
